Old 07-13-2009, 06:06 PM
69gtocv 69gtocv is offline
Originally Posted by Roadbuster View Post
I run R888s front and rear on my 68 GTO. 255/35R18s up front on 18x9s and 305/35R18s on 18x11s out back on Forgeline S03 wheels.
Jon
That is KILLER looking!
Old 07-14-2009, 03:14 PM
69goatboy's Avatar
69goatboy 69goatboy is offline
Jon
I am normally VERY outspoken about how cheesy large rims/wheels look on A-Bodies ( I cannot stand the rubber-band look), but I have to say your combo looks downright awesome to me.
Might be the black centers, it seems to cut down on the "large-ness" of some of the other chromed or polished large rims.
The joker in the deck keeps sending me his card.
Smiling friendly, he takes me in.
Then breaks my back in a game I can't win.
Old 07-14-2009, 07:25 PM
I think you hit the nail on the head there. The black is what does it. I agree, too large of shiny wheels just doesn't look proportionate on an A body.
Old 07-15-2009, 09:55 AM
ilo ilo is offline
The tire rim combo look so good on your car you can hardly notice the nasty rusty exhaust
pipe coming out the side.... Better then mine... I have a really nice clean exhaust with a
nasty rusty car above it...
It has the perfect rake to it and the paint is smooth as glass..
The best looking orange 68 I have ever seen... and I've seen a ton of them.
Would love to see more pictures...
James Aiello
1968 GTO H.O. 4spd
Old 07-17-2009, 08:12 PM
Roadbuster's Avatar
Roadbuster Roadbuster is offline
Thanks everyone for the compliments. I'm glad you like the car and humbled by all the praise.
Originally Posted by goatless View Post
Wow! That looks badass! Did you need to modify the wheel wells to fit those wide rears on?
What's the backspace/offset on the wheels? Those specs on the non-OEM wheels would be good to know for the guys looking for aftermarket wheels that'll fit.
Goatless, My front suspension is a custom set up from SC&C and I have a narrow rear axle. Because of this my back space numbers won't help anyone unless they match my setup exactly. There is no room for error on the front. I was off a bit and the wheel hit the control arm at lock until I aligned it. Out back you will have to massage the back of the inner wheel well a tad bit. Make sure your body is centered on the frame. I can help with locations that need to be measured but this has very little clearance and really needs to be measured.
Thanks ilo, I cut about 6 inches of rusty pipe off just leaving a little turn out under the car. Looks much better. Replacing the pipes is on my to-do list. It is still a work in progress.
Jon
1968 GTO with SC&C Suspension
Old 07-19-2009, 08:40 AM
A few more shots for reference.
Close up of rear wheel well with 225/70/14.
Close up of rear wheel well with 275/60/15.
Shot of the clearance at top lip of wheel well with 275/60/15 **Mounted on OEM 15X7 Rally II**
Comparison of height and width of tires all setting on flat asphalt lined up evenly.
From left to right 225/70/14, G70-14 and 275/60/15. You'll notice that a 225/70/14 is still a fair amount shorter than the original equipment G70's.
Goatless,
The picture comparing the 225/70/14 to the G70 is interesting, I have Firestone G70`s and they seem to be lower and wider tread than 225 70 TA`s. interesting
On my A bodies I run the following,
69 LeMans convert, factory 14x6 black steelies with wire wheel covers and 215/75/14 dean alpha 5/8" whitewall. (this size tire is almost extinct, no major brands make it anymore hence being stuck with these crappy $40 tires). I like that look and wanted the car to have that stock "regular" look.
69 GTO hardtop, 14x7 RII with repro radial redlines (called silvertown but look just like TA`s). Not bad setup as the 7" rims fill out the tubs better than 6" but you loose the sidewall bulge which I always thought looks tough.
69 GTO convertible, 14x6 RII with Firestock wide oval G70. rides like total crap but looks great, love the square shoulder look and the bulging sidewall. Also as goatless mentioned they hook up nicely compared to a radial, especially at lower psi. But man they ride like garbage!!
Old 07-19-2009, 01:17 PM
The Boss's Avatar
The Boss The Boss is offline
New sneakers for an old goat....I know it's a 72 but...
Pulled the 15 y.o. rubber off and put on some vintage looking Dunlops. Two of the original honey's were looking rough so I pulled two more out of the parts department and grabbed a new set of trim rings. Thanks for the help Jeremy.
ID:	175306   Click image for larger version
And go racin' in the street.
Old 07-19-2009, 03:10 PM
The Boss's Avatar
Update: Tires suck - no traction!
Old 07-19-2009, 11:23 PM
nogto nogto is offline
Default wheels and tires 69 lemans
I have the exact same triple green (orig. colors) 69 LeMans conv. as goatless. I have inserted some pics of wheels and tires taken before restoration began. As you can see from the center caps and rims they are late 70's (?) era 15x7 inch wheels with 235/60/15 radial tires. I like the way this size looks and handles so I have decided to restore these wheels with original style caps and rims. There is plenty of room for the lower profile 60 series tires without any suspension mods.
Name:	side view 0408.jpg
ID:	175394   Click image for larger version
Name:	rear wheel 0408.jpg
ID:	175396   Click image for larger version
Name:	front wheel 0408.jpg
Old 08-22-2009, 06:31 PM
ramairthreegto's Avatar
ramairthreegto ramairthreegto is offline
Thanks for this post-
Here is how r14 225/70s up front on 14x6 rally IIs up front and r15 275/60s on 15x7 Rally IIs ends up. I was going to be safe and stick with 255s in back, but really wanted the extra diameter of the 275s for help with RPMs at higher speeds.
For the record, in my tastes, muscle cars need rear tires that are a little wider, taller, and with more sidewall than up front. Not the best plan for tire rotation. I know the rake look is outdated but I am cool with old school. Also makes your r14 225/70 spare tire not the best for if you get a flat in a rear tire, but still a lot better than the mini donuts they call spares now.
"Yes, it's a real GTO. I know the scoops, spoiler, exhaust tips, and rear wheels are wrong. Umm, sure it's the 'big block' 400, you are quite the expert. I am driving in the rain, at night, running errands, with the kids who are eating and having ice cream in the back, after going to the drag strip, burning rubber, and blowing donuts. Do you really think it's numbers matching all original?"
Old 08-22-2009, 08:07 PM
Aus Goat Aus Goat is offline
ramairthreegto
whats the color of your car? looks great nice and deep
Old 08-22-2009, 10:18 PM
Originally Posted by Aus Goat View Post
ramairthreegto
Matador Red
that's the color it originally was.
except it left the factory with a black vinyl roof.
I was either going to do the roof or judge apearance.
(I dont think there are Judges with vinyl roofs)
It was easier doing the decals and went with that.
In general, I prefer a brighter red, candy apple, torch red, etc.,
but this has grown on me.
But when the day comes to repaint it, solar red would be tempting.
Old 08-23-2009, 06:40 AM
I wouldn't touch it. That deep Matador hue looks mean on it...especially with the flat black accents. Very nice car!
Old 09-08-2009, 11:26 PM
Curly Joe's Avatar
Curly Joe Curly Joe is offline
Thumbs up 69
lookin good.
"Chief" Knucklehead
462 E Heads Solid Roller 91 Octane Nash Stick
Old 04-28-2010, 12:30 AM
PaulatFast PaulatFast is offline
Originally Posted by ramairthreegto View Post
Matador Red
There were lots of Judges with vinyl tops. I'm finishing up a Carousel/black vinyl Judge right now.
Paul
FAST Automotive -The Pontiac restoration shop, not the fuel injection guys! I had the name first.
My site... needs updated-
www.fastrestorations.com
68 GTO's (RA II, RA I, HO, convert, Pro Street, Racecar, etc.), 2 69 GTO Judges, 70 GTO racecar -10.77 @ 124mph, 68 Tempest survivor, 3 03 Aztecs!
Old 06-09-2010, 08:10 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Originally Posted by Curly Joe View Post
lookin good.
Joe is that your car....it is sick.
What are the specs?
John
Old 06-10-2010, 06:54 AM
trishieldchief's Avatar
Dog Dish with Redlines
Rich Johns
www.purestockauto.com
1970 GS 455 M21 4 Speed 3.42
1987 GN Astro Roof
  #38
Old 06-10-2010, 08:39 AM
Ron Landis's Avatar
Thumbs up Ditto...
Originally Posted by srickss View Post
Poverty caps with redlines is the obvious choice.
only with the body color wheels!
  #39
Old 06-10-2010, 01:11 PM
Jack Peters's Avatar
I know it is a '71 but same basic body style. Back in the day. Here are G60's in the back and F60's in the front. 15 X 7 slot mags. Ansen. No idea of back spacing. Only rubbed at lock on upper edge of front inner fender.
JLP
  #40
Old 06-11-2010, 09:05 PM
goatless's Avatar
goatless goatless is offline
G70-14 (the same ones from the beginning of this thread) on my '70 T-37.
Dogdish hubcaps everywhere!
1966 GTO
