Patch panels
I need to do some work on my quarters
What r u guys using to cut the panels with??? I have a Makita I think 4 1/2" grinder is there somethin to put on this to cut out my panels with and then use it to grind my welds down with........Thanks for any help again as usual....Chris
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's |
You can get 4 1/2 cutting wheels to fit your grinder. They are only designed to be used on edge, so if you have a lot of grinding to do, buy a grinding wheel, which is thicker.
Quality wheels are not very expensive, so having a few cutting wheels and a grinding wheel, would be a good start. Dave |
yeah just use the cutoff wheels made for your grinder size, to get a nice straight cut just use masking tape then follow the edge of the tape for a nice straight cut
Just what I did when replacing my partial quarters. Tape and follow the outline.
1974 400 4 speed |
TransAmRIP, I hope you had a clear lens in that welding helmet!!
I found a corded die grinder at of all places,Harbor Freight.It was 39.00 dollars and performed flawlessly.I couldnt stand my noisy a$$ compressor going off every two seconds!I dont advocate buying cheap tools,BUT,for something like this,it was great.
Of the 3 angle grinders I have used on my resto so far, the Makita has outlasted the other 2 by orders of magnitude. One was a Craftsman, but I forget the other.
While getting the cutting wheels, I suggest grabbing the a grinding wheel or 3, some flap sanders (horizontal and vertical) and a knotted wire brush (great for removing crud, paint, and bondo- but wear a dust mask). Also, I strongly suggest wearing full gloves and face shield when using a knotted wire brush. Occasionally it "sheds" a wire which is like a mini-bullet. I had one make it through my welding gloves right into a finger knuckle. -J
"If you can’t fly then run, if you can’t run then walk, if you can’t walk then crawl, but whatever you do you have to keep moving forward." |
Thanks for the replies guys
I know the cutting disc should be about 1/16" in thickness for the cuts to get a good gap for butt welding As for the Grinding disc is there a certain Grit type I want to start grinding with???...Chris
I use my IR air saw whenever possible.
I get the 3M green corps 1/32" wheels for cutting. Grinding discs I use the green 3M 40 grit. Also to get some high welds down I use my grinder discs. You can double up 2 of the 1/32" ones for extra control.
-Jeremy 1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio. 1962 Catalina convertible, Starlight black w maroon interior & white top. |
Thats actually my son, and yes it had a clear lens!
1974 400 4 speed |
Ok guys thanks for the input gonna hopefully tackle this at some point soon ...
