#48 heads dates: A309, B269 NEW valves etc
For sale:
#48 Pontiac heads Magnaflux test passed Pressure test passed Recent machine shop receipt included shot tumbled end freeze plugs removed dip cleaned by Metal Rehab to remove all internal & external corrosion In 1974, I found these heads in the trunk of a Ram Air III 69 GTO Judge. At the time, these heads were only 5 years old. The block in the car had the heads removed, so I am pretty sure these were the original heads from that Judge. These heads had aluminum retainers & poly locks on them, so it is likely that they have had, very low miles &, at the most, only one valve job since new. I never used them & they have been in my storage since then, (for 35 years). They are un-ported, unmodified, & as virgin as you are likely to find. Date codes: A309 B269 Exhaust ports painted with a base coat of Eastwood 1200 degree high temp stainless steel silver, to prevent these areas from external rust from the heat. Eastwood Cast Iron gray used on normally non painted areas to prevent future rust. Correct Pontiac blue for 1969 on the normally painted areas. Includes: New TRW valves, correct for these heads TRW 1984 Catalog list the application as: 68-70 400 4 bbl. & Ram Air III 8 intake valves V-2639 Intake 2.11 dia. 30 degree seat 5.093 length 9 exhaust valves (1) extra. S-2638 Exhaust 1.77 dia. 45 degree seat 5.093 length 16 3/8" poly locks 16 original rocker arm studs, dip cleaned 16 original rocker arms & balls (each rocker arm was kept with it’s matching ball), dip cleaned 3 original guide plates, dip cleaned I am including an aftermarket guide plate kit. It is a different style, but it should function like the originals. 16 NEW valve springs HO Racing VS-11 useful for slightly reduced installed tension for running unleaded gas Installed tension 120 lb. @ 1.59 Open tension 240 lb. @ .450 Max lift .500 16 NEW steel retainers 16 NEW steel keepers Eric (817) 491-4702 email me for more photos ericread@bwdmail.net Will ship in 3 boxes There will be an additional charge for packing. Ebay Item number: 120461479313 bids start at $500 http://cgi.ebay.com/ebaymotors/ws/eB...m=120461479313 |
Im in.
Ended the Auction.
Heads no longer available for sale. Eric L. |
Thanks for the warning
