Old 06-18-2009, 09:05 PM
jal's Avatar
jal jal is offline
Default 1983 Pontiac Bonneville ( g-body ) Station Wagon
I'm posting this for my brother Adam. If there is any interest, I'll put you in touch with him.
The car is located in Horsham, Pa.
Pictures of the car can be seen here.
http://picasaweb.google.com/atecht/83BonnevilleWagon#
Asking $3000.00
1983 Pontiac Bonneville ( g-body ) Station Wagon.
Drive Train:
350 SBC. All stock except for recently rebuilt 1.94 cylinder heads (888 casting), Edelbrock Performer RPM intake manifold(powder coated black), 600 dp Holley carb, Edelbrock cast aluminum tall valve covers, and a Edelbrock high volume mechanical fuel pump. K&N Air Cleaner with 14”x3” K&N reusable filter. GM Serpentine Belt conversion ( powder coated black from late model f body ) with a CS 1 wire 140 amp alternator and high flow reverse rotation water pump. Ceramic coated (still in decent shape) 1 5/8 Hedman shortie headers connecting to a Pypes G body 2 ½” mandrel bent true dual exhaust system using Pypes high flow catalytic converters, Pypes high flow mufflers and an X pipe. The tail pipes exit right behind the rear tires GN style. About two weeks after the heads were rebuilt, the engine developed a noise. The noise isn’t always present but you hear it more often after the engine is hot. I’m assuming it’s a bottom end noise, but I’m not positive.
Turbo 400 transmission with a P.A.E. (http://www.paeenterprises.com/paeproducts8.html) switch pitch conversion including their PAE3000 torque converter. It gives about a 1200 low stall, and a 3000 high stall. It’s bolted in using a “maliburacing.com” Iceman cross member.
The rear is a Chevy 12bolt out of a 1970 Chevelle, bolted in using conversion control arms. It’s got a 3.08 gear with a GM posi unit.
Chassis:
The front suspension was completely rebuilt 3yrs ago using a PST suspension kit and Moog coil springs (front and rear). Everything on the front end (except the center link) was replaced. Brakes, rotors, hoses, steel lines, etc….. I also installed a rebuilt GN quick ratio steering box. It has an Addco front sway bar using polyurethane bushings on the frame and end links. I also added a Hurst line loc while I had everything apart. The line loc is actuated thru the cruise control button. KYB high pressure gas shocks are used on all four corners. Corvette style Rally wheels are used all around with 15x6 on the front, and 15x8 ( 275/60/15 ) on the rear. No trim rings are installed, instead I used the small stainless steel police center caps.
Body/Frame:
The car was originally white and was repainted white. All the side and wheel well moldings were removed, along with any side and name plate emblems, and all the holes were filled. The rear wheel well inner lips were trimmed. The roof rack was removed, but the chrome roof strips are still installed. While the front end was apart for the rebuild, a frame repair around the steering box/sway bar mount area was done and the entire front frame was pressure washed and then painted with POR-15. The rear frame rails are in great shape. There is some body work starting to show where the molding holes were filled, and at the bottom of the rear quarters, but it’s no where near extensive and should be straight forward to repair. The floor boards are in good shape. The rear bumper is in great shape and the chrome is good.
Interior:
I started restoring the interior, but it’s not complete. It was originally a split bench. I’ve replaced the bench with a pair of buckets. Basically the drivers compartment is complete. Everything behind the driver still needs some work. The power window motors were replaced. The dash is the typical Bonneville/Lemans/Grand Prix gauged dash. The tach, water temp, oil pressure, and
volt meter gauges have all been replaced with VDO performance gauges. The speedometer, and fuel level gauges are original. A Grant GT three spoke wood grained steering wheel has also been installed.
Old 07-01-2009, 07:59 AM
jal's Avatar
jal jal is offline
Will also sell the car as a roller. Less engine & transmission.
Would make a nice street / bracket car.
`joe
Old 07-19-2009, 09:28 PM
jal's Avatar
jal jal is offline
TTT
Old 08-11-2009, 09:20 PM
jal's Avatar
jal jal is offline
Bump
Old 09-13-2009, 09:57 AM
jal's Avatar
jal jal is offline
Back TTT
This is about to parted out..
Old 09-14-2009, 08:15 PM
Jagtec1's Avatar
Jagtec1 Jagtec1 is offline
It would be a shame to see this car parted out. If I had the extra $, I would have it as a daily driver.
Darin
'64 Bonneville Wagon (sold)
69 Lemans-All motor (sold)
9.81 @ 136.39MPH
Old 09-14-2009, 08:40 PM
Scott M's Avatar
Scott M Scott M is offline
Question
How much without the boat anchor motor and transmission?
Does the car have a current PA inspection AND emissions sticker?
What axles does it have?
Thanks.
Old 09-14-2009, 08:43 PM
jal's Avatar
jal jal is offline
Hey Darin,
I know what you mean but, he needs the money for other projects.
He's had some interest but, just people kicking the tires.
Honestly, there's a lot of good parts in that car.
Just the TH400 with the switch pitch converter is killer.
Hopefully, someone will give it a good home soon before I'm over there helping him pull all the parts off of it.....
joe
Old 09-14-2009, 09:01 PM
jal's Avatar
jal jal is offline
Scott,
$2500 as a roller.
The PA inspection is good through the end of this month (September).
The axles are the stock GM 12-bolt pieces. It is also a C-clip rear (stock).
I don't believe that there is an emissions sticker since, the car saw under 5k miles.
But, I can check if needed.
joe
Old 09-22-2009, 01:29 PM
jal's Avatar
jal jal is offline
Okay, boys and girls. Last chance as a whole car.
We start parting it out this weekend (09-26-2009).
