Old 10-05-2009, 08:13 AM
rotdog rotdog is offline
Default 64 camino suspension under 65 lemans
Just bought another 64 elky the body is shot. It has rebuilt everything under front and rear. My question is will all the frontend stuff work under my 65 lemans? Thanks in advance
Old 10-05-2009, 07:16 PM
All of the '64 El Camino suspension parts will bolt directly onto your '65 LeMans.
Old 10-05-2009, 10:34 PM
Thanks, Good to hear from people that know.
Old 10-05-2009, 10:49 PM
The '64 -'72 GM A-body cars share a lot of the same suspension components.
The front end on my '64 GTO has lower control arms off of a '67 Olds Cutlass wagon, the front disc brake rotors and spindles came from a '69 Grand Prix.
The easy interchange of chassis and brake parts between the different GM brands over many model years is a big reason why these cars are so popular today.
Old 10-07-2009, 11:09 PM
Colin Frolick's Avatar
Colin Frolick Colin Frolick is offline
the El Camino frame rails should also be fully "boxed" for strength, you could put the whole frame under your Pontiac to stiffen the platform.
Old 10-08-2009, 02:34 AM
Thank's, I didn't mention it is a rag top another reason i got the camino is for the frame to use at latter date. Rust Sucks.
