My twin turbo 281 4.6 STREET CAR runs 9's with tilt cruise air. You would be impressed with any modular engine with a power adder TRUST me. The 4.6 n/a is a turd. I still have my poncho's but nothing even comes close to my Ford in terms of power for the buck. I still use a stock crank, intake, block, heads, cams, timing chains, and weigh in at nearly 3800 pounds with me. All I bought was studs for everything, twin 61mm turbo's and although I didn't need it I got a big stuff3 to run everything which may be coming out soon to go back to stock pcm. The Mach off the showroom floor ran 13.17 and 11.80 with a 100 shot, not too bad for a 281. You will enjoy the Mustangs. So far I've made 800 to the rear wheels and should go 1000 to 1100 next year once we figure some crap out
HI, I'M RICKY BOBBY, AND IF YOU DON'T CHEW BIG RED GUM, THEN F*(& YOU!
