#121
We will work with what you have. Some 455 blocks get too thin to go out to 0.060 without filling. We magnaflux every rod, crank, and block. We also sonic check all cylinders for wall thickness. There is only one way to do a RA-V and we have been working with them since 1975. BES is simply up there with one of the best machinist out there, and they will be doing all my machine work. Lynn Last edited by NHRASuperStock455SD; 10-24-2009 at 11:39 AM. |
#122
Lynn |
#123
Like Lynn said, no water jackets would be for a drag race only application on alcohol (or perhaps nitromethane).
#124
Would be really nice to see a Pontiac SOHC RAV Engine (Hint hint). Tom Vaught
#125
I can't wait to get my hands on a set with jackets to send to my ole pal Dave B, I got to have a set on my 537 street/strip motor, Lynn ill be using a fairly aggressive sollid roller But i'm waiting on getting one because of this 5 deal, with all the goodies ie Bigger cubes-11.3:1 comp, 270ish sollid roller .750lift Do these heads have the capability to support 850+hp on pump gas?
D.S.R.E. Your NW Pontiac Street/Strip Engine Builder, Specializing in Cylinder Head,Intake Manifold,and Exhaust Manifold Porting services and Building the Most Efficient stock rebuilds to Hi HP Pump Gas and Race Combinations for Pontiac,Buicks,Olds,FE Fords,385 Series and HP Gen 3 and 4 LS engines! 2006 silvy Z71 4X4,383 LS 600+hp NA Shared Toy-66 Lemans 470cid by me 537hp 580tq-manifolds, 570hp 590tq-2"headers,custom cam,rpm intake, mild e-heads, Looks stock ;-} |
#126
Only 850?
Lynn |
#127
Maybe I missed it but whats up with valve size and angle? Can we expect to need new matching pistons for the V or will our existing pistons be close enough with maybe a bit of gouging? Example: my Ross set up for 2.25 intake?
#128
I am a philanthropist, but for little kids not Pontiac guys, it depends if we have any takers for the additional cost. Tony Bishoff and I talked about that pushrod location yesterday. I said, why dont we just take out the pushrods? He looked at me with that crazy look, but after seeing the RA-V casting he knows how crazy nut-so I am. Lynn |
#129
Look at the new Modular Ford Engines. No super long chain. (long is a relative term).
Tom Vaught
#130
We are trying to design the street heads as painless conversion as possible. Lynn |
#131
Tom,
I have a Police Intercepter engine in my shop 1998, is it like that one? My son said that engine is a toad, but I thought it looked killer. Lynn |
#132
If you look at a Lightning Truck Set-up you will see that it uses a "double sprocket" crank gear (like a double roller chain), You can run one link chain to each head/ camshaft and use 2 short chains.
Lots of room in a pontiac timing cover area for a dual chain drive to the heads. Tom Vaught
#133
Imo a belt drive might be an easier way. All kinds of options with todays belting. Plenty of support from belting companies in designing your belt system as well. I got 30 plus years of belting experience and very positive of Gates products and support and reliability.
#134
Tom,
What are your ideas about a best system verses a chain? Lynn |
#135
Any news?
#136
That is the main reason why Ford went with a chain on the 4 valve stuff. If you have a "free wheeling" engine (you can turn the engine over at full valve lift through the complete piston motion without interference) then you can typically use a belt. If you have a Non "free wheeling" system if the belt breaks the owner will not be a happy guy and will come after you for the repairs, unless it is a Pure RACE deal. I like Chains. Tom Vaught
#137
Thanks - Brian |
#138
The first few heads are poured and at the heat treat shop waiting in line. The street 455 RA-V (RS) street engine is a .070 bore and 4.250 stroke with a cast crank all done ready to go!
The water jackets cores came out slick, we will see what they all sonic check to and if Tony wants any changes for porting areas. Lynn PS...RS = Regular S*&^ |
#139
Glad to see that you are getting some "V" heads cast up. Ballpark cost for finished heads?
Tom Vaught
#140
Now I am trying to decide on valves. We already made the decision to scrap the 3/8 valve stem and go with a 11/32 on the street head that significantly reduces valve weight. The OAL is 5.75 inches at my insistence. Since the RA-V only came with hollow stem intake valves and sodium filled exhaust, then I think we should keep with the killer Pontiac tradition in light weight valve train. Any suggestions? Hollow stem? Titanium? I really hate the thought of doing a RA-V with stainless valves, it does doesnt sit well with me. Thoughts? Sorry I havent posted in awhile we have been doing testing on a new patented process for clean coal technology. It passed for SOx and NOx, now we are going after Mercury. We are doing the designs for a $100,000 boiler testing apparatus for continuous coal burn testing. thanks, Lynn [email protected] 317-839-8378 |
