Old 02-15-2010, 04:56 PM
gtos's Avatar
gtos gtos is offline
Default Loading a Motorcycle into pickup truck
I have a full size Dodge truck. I am buying a Harley Road King & plan on transporting it in the bed of the truck. Are the tailgate support cables capable of handling the weight about 750 lbs. We will be using ramps to push it on. It will only be on the tailgate for less than a minute.
Old 02-15-2010, 05:14 PM
The Boss's Avatar
The Boss The Boss is offline
You should be fine, ever sit on the tailgate with two of your friends?
And go racin' in the street.
Old 02-15-2010, 05:15 PM
sleepy's Avatar
sleepy sleepy is offline
Yes.
Why is he not suspended?
Old 02-15-2010, 05:17 PM
Deadhead's Avatar
Deadhead Deadhead is offline
I would take the gate off & do it that way. I loaded a 70s Honda (750?) into my '01 2500HD, & it did make it across the gate, but after that I rolled something a little heavier over it and it completely tweaked the hinges etc. I was able to fix it with some careful work, but I also believe that the gate got a bow in it.
Long post short- I felt stupid for not taking the gate off to load when I ended up having to take it off to fix the bent crap after the fact.
"If you do everything you'll win"
-LBJ
13 Smiles per Gallon:
66 Bonneville wagon
66 Bonneville 2d HT - In perpetual progress
2005 GMC L-33
Old 02-15-2010, 05:18 PM
mwritter's Avatar
mwritter mwritter is offline
I think most fullsize tailgates are conservatively rated at 500lbs in the center. If you are careful, you'll never have the full 750 on the gate itself, it will be distributed to the ramp and bed itself as well. Just be careful where you're standing as that could be the extra weight that makes the difference.
You could always remove the tailgate and load directly into the bed if it will fit and the angles work. That's what I do but I've got sportbikes, light and short.
Matt
1962 Grand Prix - Cameo Ivory|389 4sp|One-Owner Survivor
1964 GTO HT - Silvermist Grey|389 3x2s 4spd|A/C|Hurst Wheels|Frame-off|SOLD
1965 GTO Post - Mayfair Maize|421 3x2s TKO600|Pro-Touring|
1966 GTO HT - Barrier Blue|389 3x2s 4spd|Red Fenderliners
2005 GTO Coupe - Yellow Jacket|Magnacharged LS2 6sp|543hp/561tq|SOLD
2006 GTO Coupe - Spice Red|LS2 6sp|20k orig miles
Old 02-15-2010, 06:54 PM
TooLow TooLow is offline
If I remember right back when I had my full size chevy [short bed] I had to leave the gate on as the back tire of my roadking rested 1/2 on the bed & 1/2 on the gate when loaded. Never had any problems with the weight hurting the tailgate. I currently have a 65 elcamino and have hauled the RK in that also without any dammage to the gate. I would do a good inspection of the support cables before loading the bike though. Just to be on the safe side. They seem to rust and fray very quickly on newer trucks.
Old 02-16-2010, 05:47 AM
stimpy stimpy is offline
take 5 minutes remove the tailgate , having a bike fall on you from that height is not comfortable , at the dealership they refuse to load the bikes with the tailgate on , I use the gap for the plate as a ramp guide and use good nylon( 3500 rating ) tiedowns to hold the ramp to the truck by using the safety chain slots in the trailer hitch as I had a ramp try to kick out while loading my RD and its only 400 punds
Old 02-16-2010, 05:36 PM
GT182's Avatar
GT182 GT182 is offline
Play it even safer.... borrow a trailer with a dropdown tailgate ramp.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
