Old 12-17-2009, 12:41 AM
67'7F6'Bird's Avatar
Here is more progress, and in picture 4 you can see Ed's 68 Convertible Firebird, and 69 Camaro awaiting an IA2, Heads not yet determined. Oh and Picture 3 is Ed and 'Craig the truck driver.'
ID:	191126   Click image for larger version
ID:	191127   Click image for larger version
ID:	191128   Click image for larger version
ID:	191129   Click image for larger version
  #202
Old 12-17-2009, 10:24 PM
mysticmissle's Avatar
merry christmas to you!
  #203
Old 01-26-2010, 07:52 PM
I dropped of my '7F6' heads at R&L engines in Dover NH today. Having a few things done.
  #204
Old 02-01-2010, 03:20 PM
Received a call from Leo at R&L Engines:
The heads have been disassembled, cleaned and checked for cracks; everything looked good.
No problems with the guides and the valve seats are standing proud - new term I learned.
We're gonna check the flow on a few ports before we move forward. I am probably gonna have the crossover filled. He said the existing port work was very mild, the stock shape was barely modified, all good news he said.
Head flow results in a few days.
Steve
  #205
Old 02-05-2010, 04:27 PM
Here are the Flow numbers.
Intake is listed first as 7F6.pdf,
Exhaust is listed as 7F6E.pdf.
  #206
Old 02-05-2010, 04:44 PM
Here is a chart comparing my 72 7F6 heads to my brothers RAIV's.
  #207
Old 02-05-2010, 09:59 PM
Click on Chart.
  #208
Old 02-26-2010, 06:54 PM
Here's a picture of the head, valve bowl area cleaned up and valve job performed.
Still need a little more work before reassembly.
  #209
Old 04-02-2010, 09:37 PM
I got my heads back from R&L today. The ports look really good and the flow has now been corrected and increased. Thanks to LEO at R&L and Len Caverly for their help on these old heads.
  #210
Old 04-02-2010, 09:51 PM
I have attached the FINAL FLOW CHART for my 72 7F6 heads.
Click on link.
  #211
Old 05-19-2010, 07:44 PM
My 455 block has finally been rebuilt by Lawrence Crankshaft.
I should be able to pick it up this weekend.
Honed, new bearings, turned crank.
  #212
Old 05-30-2010, 10:35 AM
My Brother Ed and I started to get the engine back together. Cleaning out all the threads to get ready to install the ARP Head Studs. Twist them in until they bottom out, then loosen a 1/4 turn. Molly lube is used on all the threads. More assembly today.
ID:	207746   Click image for larger version
ID:	207747   Click image for larger version
ID:	207748   Click image for larger version
ID:	207749   Click image for larger version
  #213
Old 05-31-2010, 07:23 PM
More assembly pictures.
We did find out that my new louvered CANTON Windage Tray doe not fit with my aluminum rods.
The lower 2 louvers need to be modified.
ID:	207874   Click image for larger version
ID:	207875   Click image for larger version
  #214
Old 06-20-2010, 08:30 PM
We installed the Solid Roller Cam this weekend. We are going to degree the cam in next.
ID:	209613   Click image for larger version
ID:	209614   Click image for larger version
ID:	209615   Click image for larger version
ID:	209616   Click image for larger version
  #215
Old 09-18-2010, 10:39 PM
Working on installing the fuel system.
Aeromotive A1000 Pump
10 and 100 micron filters
10 AN push lock hose for both the feed and return line
ID:	218937   Click image for larger version
ID:	218938   Click image for larger version
ID:	218939   Click image for larger version
ID:	218940   Click image for larger version
  #216
Old 09-20-2010, 08:14 PM
Installed the new disc brake dust shields, painted all the support bars for the front suspension and brakes. Installed the master cylinder and new stainless brake lines from INLINE TUBE.
ID:	219117   Click image for larger version
ID:	219118   Click image for larger version
ID:	219119   Click image for larger version
ID:	219120   Click image for larger version
  #217
Old 09-27-2010, 01:15 PM
Tempest's Avatar
Tempest Tempest is offline
Great work, I have been following this thread for a while. From pics 1 and 4 in post #216 it appears that the calipers have been installed on the wrong sides, as I believe the bleeder should be on the top side of the caliper, this will allow air to escape the system when you bleed. Please others chime in to confirm this.
  #218
Old 09-27-2010, 02:18 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Good catch Tempest, you're right, the bleeder should be up.
  #219
Old 11-06-2010, 10:50 AM
HO 455 Being installed today.
  #220
Old 11-06-2010, 10:57 AM
RAIV-Z's Avatar
Default This one?
I don't think it will fit under the hood!
