Old 04-09-2014, 02:56 AM
marks73ta's Avatar
marks73ta marks73ta is offline
It was an attempt to run turbos back then. It was mechanical FI, not EFI. Proper carbs will normally out power FI but the ease of tuning the EFI now far outweighs the difference or loss if any from carbs. I would do it for the better street manners the EFi affords us. For all out strip it's not as big of a deal. Although, from what I've read, blow thru carbs may reach a point where they can not properly atomize the fuel/air at high boost/flow situations. I don't know that as fact but have seen comment towards that. I'm sure time will tell as more racers find that limit, if it's a fact.
Mark
My Gasser '63 Catalina build. Oh sorry, it's a Street freak. Either way it's a fun build.
Old 04-09-2014, 03:04 AM
marks73ta's Avatar
Paul (Westcott) I may just have to talk more with Tom and see what unit will work best for me. I already have the injector ports on the manifold. I have two sets of Edlebrock fuel rails. You can find cheap factory throttle bodies anywhere. The big cost will be the computer control unit (MS or?) and injectors. I would also lean towards coil on plug as well.
The control unit I use will need capabilities for fuel, ignition, boost control, possibly 16 injectors, coil on plug, etc, to work for me.
Mark
Old 04-09-2014, 12:08 PM
Paul Westcott's Avatar
Paul Westcott Paul Westcott is offline
Mark
The MS II v3.0 ECU in my car cost just about $300 to build as a kit. You don't have to build it, you can buy it complete. A new MS III ECU (built) is $600... I challenge anyone to show me an aftermarket ECU that has this level of performance, reliability and tuning capability for less $. Remember, everything is open source! You're not paying for someone to slap their brand name on it (Holley, Edelbrock, etc,). MS will handle all the capabilities you list above... it can be set up to run anything: 2 cylinders to 12. Boost. Juice. Electronic auto trans... no problem. The tuning software (Tuner Studio for MS) is free too.
You're right, any throttle body of appropriate size will work... it's just an air valve. I use an older, 1000 cfm Holley TBI, minus the injector pods, as a throttle body. It has the TPS and IAC built in. In your application, it would still look like a blow-thru carb set up, sort of...
I got my injectors off ebay for about $80, new in the box (LS1, Bosch type, 36pph ). Obviously, yours need to be sized to their task.
http://www.megamanual.com/index.html
http://www.diyautotune.com/catalog/m...-iii-c-76.html
I'm a huge fan of old school brute horsepower controlled by modern day electronics... maybe you can tell.
I also like to save a buck where I can.
The 1967 Rustbelt Refugee. Work in progress. Donations accepted.
- 467 Cubic Inch EFI Pontiac, Megasquirt II v.3.O ECU, 700R4, 3.55 gears -
Best 1/4-mile ET: 12.79 @ 107.36 MPH - Best Fuel Economy: 18.47 MPG
...That's no GTO, that's a Tempest!
Old 04-10-2014, 10:39 AM
I'll add to Pauls comment on MS... I researched just about everything out there... Capabilities etc.. Also sampled some tuning software to see how good the human interface was... The 3rd consideration was support and parts availability... last was price.
Hands down MS comes in on top when you put all those factors together. Tuner Studio is pretty easy to get a feel for... Most parts you can get anywhere any time except the ECU and its pretty rock solid. Features are equal or better than the name brands, Support... usually you can(will IMO) find your answers on the web site. With plenty of users that have the answers because someone has been there done that good or bad and has that knowledge to pass forward 24/7.
MS3 pro ECU and Harness is a top shelf deal and going for around $1300 last I looked... Does everything you need(very well) and more. Datalogging abilities(high capacity) onboard, auto tuning, boost control, shift control...basically a full blown engine/drivetrain management system. Turn on what you need add features later without having to buy the features "locked" by the manufacturer when it was built
The Accell ignition stuff I sold you will work fine with your blow-thru its a good ignition setup with nice features...but reason I abandoned the plan was finding out how much more I could do with the MS stuff... even MS2.
Imo decide how much of your turbo's HP capability you will feel comfortable using and buy the injectors that meet the fuel requirement at no more than 90% of their 100% duty cycle rating. (85% is safer yet) Good injectors arent cheap but thats an area you dont want to skimp on.
Good news is your Blow-thru stuff will sell at fair price and often if you trust the source you can find deals on used injectors from a racer stepping to higher levels. Things like throttle bodies and sensors can be used stuff from a wreck or new stuff from your favorite local auto parts store.
I'll make you a hard copy of info from Ford racing that does a great job of explaining how to properly select fuel injection components. About 5 pages and probably only info you wont use is choosing MAF size(unless you are buildn somethin we dont know about). Check your mail next week!
I'm pretty certain I'll be using two single barrel throttle bodies linked in tandem somewhere on the front of a ram type manifold. Possibly make box type ram that houses an a/w intercooler core...
Old 04-10-2014, 02:23 PM
marks73ta's Avatar
Thanks Bruce. I'll watch for it. I just have to look at costs versus what I can sell to cover costs. Plus the time it takes to sell. But that is something I have to deal with. I just want to get it running.
Mark
Old 04-13-2014, 01:07 PM
marks73ta's Avatar
Had the Cat out for another car show. Took some pics of the car after taking it off of the trailer.
Show got really crowded and there were so many people looking at the Catalina. Really made me feel good. At any time there was always a crowd around it. I parked it next to our tent so it made for an opportunity to ask questions. Boy did they ask questions.!! All were enthusiastic and not a single bad comment was made or they kept it to themselves. It was very rewarding. I had it parked such that people would round the next row (vender tents) and it faced them dead nuts on to the front of the Cat. I actually saw people stop in their tracks when it caught their eye. I think one guy had an epiphany when he first saw it. He just kept saying "Jesus Christ, Jesus Christ", over and over again.
What really made me feel good was some Father and Son interplay. More than once I saw Fathers explaining to their sons about the Gasser stuff (why the axle and the set back motor etc) and the Son explaining the turbo system. It was a really nice balance of passing information and like interests between the generations.
Mark
Old 04-13-2014, 03:43 PM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
..... I think one guy had an epiphany when he first saw it. He just kept saying "Jesus Christ, Jesus Christ", over and over again.
Mark
He obviously had a coming-to-Jesus moment. Congratulations, Mark. Yor're an excellent ambassador for Pontiacs, gassers, turbos.......etc.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
Old 04-13-2014, 01:35 PM
marks73ta's Avatar
I forgot to mention. We have a local TV show called Roddin' and Racin' here that covers the car scene for the state. They came up to me and asked for an on camera interview about the car. They said it airs in June or July if it gets on. I was totally surprised and unprepared. Totally off the cuff. I'll probably will sound like a real idiot but hey I keep up the cover for all my genius hey?? HA!!! They said they also have a u tube channel for the show so I have to go look and see if I can find it. WAIT. Maybe I don't want to watch it. LOL.
Mark
Old 04-13-2014, 09:26 PM
marks73ta's Avatar
Oh Jim (toeing the ground, head down, with a blushing mug), GOOOLLEEEE!! LOL.
Markus O'Blsuious
Old 04-13-2014, 10:26 PM
gtofreek's Avatar
gtofreek gtofreek is offline
Markus O'Blsuious
I think you meant "Markus O'Blushious". Sheesh! Weird yu lern ta spel?
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 04-13-2014, 11:30 PM
hellerods's Avatar
hellerods hellerods is offline
Default The Mark Show
Mark you're going to be a u tube sensation and probably have your own TV reality car show. How about ''Marks Gasses'' for your TV show name ? Lee
Old 04-13-2014, 09:30 PM
mechanickeith's Avatar
mechanickeith mechanickeith is offline
Ya better get that thing running soon!! I'm gettin tired of pushing it on & off the trailer!!
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 04-13-2014, 10:14 PM
marks73ta's Avatar
Shut up Keith or ya won't get your "Butler" shirt back, yeah dats right I got tied up in the chair and I ain't bein' nice!!!!
Mark
Old 04-14-2014, 01:16 AM
marks73ta's Avatar
Sheesh Paul, where'd ya lern ta read???? HA!---by the way it's code so the Martians don't see it. Long story, don't ask--LOL.
Lee, how did you know my wife calls me that. But she says I t in a more scientific manner, Mark OutGassious!!!
Markus O'Shamlessious
Old 04-15-2014, 11:32 AM
RUDOLFSSON's Avatar
RUDOLFSSON RUDOLFSSON is offline
What's the latest on the project?!?!
Old 04-15-2014, 08:22 PM
marks73ta's Avatar
Hey Kris. Lots done and lots to go. But getting close to firing the engine. I'm going to pull it and put it on a start up stand so it's easy to work on in case of leaks etc. I have several things to do to it also before firing it. Once fired and run in it goes back in. Then all the fuel and water lines have to be run. The full car wiring has to go in too. I hope to at least have it moving under its own power by Oct for the fall Central Cruise. That's my target for now. If I can actually have it on the street and driving, that would be great. I'd love to take it out on the street and do a big fat burn out for the cruise.
Mark
Old 04-15-2014, 09:26 PM
Engine-Ear's Avatar
Mark if you need/want wiring help, fly me down (and back) and I will.
RediRad circuit designs, branding and intellectual property are for sale.
Serious inquiries only.
Old 04-15-2014, 09:41 PM
Mark,
my "boss" has been buying these kits for me to install...
http://ezwiring.com/wiring_harness.html
Pretty decent kits for the money.
Also use the gauge packages and dash panels on alot of projects and pretty happy with the products.
Old 04-16-2014, 09:57 PM
marks73ta's Avatar
I bought a full Speedway wiring kit but it's been put away so long I can't even remember what kit. It's probably less complete than other kits but I should be OK once I devote time to it. I have a tendency to ignore stuff I'm not looking forward to doing until the time comes, then I dig in head first.
Matt, nothing I would like more than to fly you down for the project. But I've never wired a car before (other than crappy add on wiring) so it's about time I dig in and make it my own. Once I dig in it'll go fine. I just have to get my head into it, (ha, scarry hey???). Thank you for the offer though.
Old 04-16-2014, 10:42 PM
Mark,, You need a big radiator for the test stand?? I have a new one somewhere that was for the 69 Catalina before I sold the car. Will see if I can find it.
Keith Collier
Tech advisor
POCI.org
