Old 07-09-2010, 01:40 PM
67cruiser 67cruiser is offline
Default any thoughts on my q-jet idling issues??
IVE STUDIED CLIFF,S BOOK FOR HRS. & i still have a small idling issue id love to correct, In park my car idles about 950 rpm,s and when i drop it into gear it dyes on me. I don,t have a power valve and currantly running 65 jets, small float and a .140 fuel inlet needle seat combo.Idle tubes are at .037 Idle down channel,s set at .052, carb. comes on super strong, i just having fits with idling, any thoughts??? Going to check my float level again today, i had it set at 1/4.Timing set at 14, Both idle screws are all the way out, looking for a little help!!
Old 07-09-2010, 02:06 PM
bnorris_74's Avatar
bnorris_74 bnorris_74 is offline
Are you using vacuum advance to the distributor? Full manifold or ported vacuum?
Is your vac advance (if you're using it) set to limit the amount of advance?
I don't believe your problem is associated with the float.
If you screw the idle mixture screw(s) in all the way, will the engine stall out?
With your screws all the way out now, sounds like you still have a restriction somewhere.
Brian
Old 07-09-2010, 02:09 PM
Just checked my float, At heel of float or about 3/16 its set right on 1/4, air bleed in the horn is at .070 idle down restri. set at.045 running ported vacum off base of carb.
Old 07-09-2010, 02:18 PM
462-6spd 462-6spd is offline
Is it rich at idle? Does your carb have APT? If so, you might want to turn it in a little more to lean it out a bit, also check to see if the spring under the piston is too stiff to allow the piston to retract. Also, may want to lower your float a bit? I just rebuilt my Q-jet on my '79 TA and it was way rich at idle, I had my float set at 1/4" and it was too high for my carb.
Also, Cliff has a web site, and he has a forum that has a lot of good info, he seems to be on there quite a bit based on how many replies I see from him. Here is a link to his site. http://www.cliffshighperformance.com/
Old 07-09-2010, 02:24 PM
Murf'sDad's Avatar
Murf'sDad Murf'sDad is offline
What have you got for idle air bypass? If your idle screws aren't having and effect I believe you need little bigger idle tube. This is off the top of my head without going back to Cliff's book to check.
Stewart
1976 TA, nose converted to 1970 style, 406, ported #13 Heads, '70 iron intake without crossovers, Q-Jet - Cliff style, RARE OS manifolds, Pypes duals w/crossflow, UD 230/238 custom HR 4/7 swap cam with solid roller lifters , Hydro-Boost 4-wheel discs, 4 Speed, 3.23 posi.
“Nothing in life is so exhilarating as to be shot at without result.” - Winston Churchill
Old 07-09-2010, 02:27 PM
BVR421's Avatar
BVR421 BVR421 is offline
take care of ignition problem first
Old 07-09-2010, 02:33 PM
No ignition ploblems at all, car seems to start right up, my apologies i believe i stated channel restriction was .045 i meant .054, typing skills suck!! Not running a power piston or metering rods.
No choke either.
Old 07-09-2010, 04:07 PM
Kenth's Avatar
Kenth Kenth is offline
What engine size and camshaft used?
What carb-#?
Idle circuit upper and lower airbleeds sizes?
Vacuum present in "ported" tube at idle speed?
Idle mixture discharge ports sizes?
Old 07-11-2010, 11:03 AM
406 cubic inches, carb. 17046240, lower air bleeds .070 crower hrdraulic cam, sorry looking for my card?? As for idle ports .098 on both holes.
Old 07-11-2010, 01:59 PM
typed to fast 17056240 carb. my apologies
Old 07-11-2010, 02:36 PM
No. of the cam is 60916 Crower 278 H
Old 07-11-2010, 04:48 PM
Kenth's Avatar
I would use at least .039" idle tubes, .059" idle channels, .110 bypass air and .100" mixture needle discharge ports.
After testing you may want increase the tubes to .040" and idle channels to .064?
Old 07-11-2010, 07:52 PM
Formulas's Avatar
Formulas Formulas is offline
No power piston... did you plug the vacum feed to the power piston ?
If not then theres a vacum leak there.
If you didnt plug then just drop the piston back in there.
