Old 07-13-2010, 11:00 PM
Rastoy's Avatar
Rastoy Rastoy is offline
Default 71 LeMans Convt Wires
I picked up this car a few weeks ago. I had not intended to mess with the wires until I fixed everything else. Well, best laid plans - the switch to the top went. Got under the dash and saw a huge mess. Lots of wires not connected to anything. Under the hood I have about 5 wires that are just hanging there. Strange but everything works.
Can you guys tell me where I can find a good diagram for this car? I have several books I've bought so far and none deal with the specifics behind the dash.
Also, I found a blue wire, under the carpet on the right side of the car. It looks like it might be coming through the firewall (I need to pull everything to confirm). Any idea what it might be for?
I've never dealt with car wires before but I can wire a motorcycle in my sleep so I have a good understanding of how to proceed once I get a good diagram.
Thanks guys.
Old 07-13-2010, 11:32 PM
rustedgoat rustedgoat is offline
A factory service manual will be one of your best investments. I recall a big pull out diagram for the wiring for the whole car.
Where are you located?
"Honestly the car will only be there for a few weeks, OK maybe a month at the most"
Old 07-14-2010, 12:15 AM
Rastoy's Avatar
I'll look for one.
I'm in Northern Virginia - right next to D.C.
Old 07-14-2010, 12:11 PM
6869GTO's Avatar
6869GTO 6869GTO is offline
I would guess the blue wire is for a rear speaker.
Leo
Old 07-14-2010, 01:22 PM
PontGuy's Avatar
PontGuy PontGuy is offline
I have a single blue wire like that in my 69. It goes under the carpet, up behind the heater box, then just under the top panel in the dash and terminates at an open connector. I am sure it is an original factory wire because it has one of those plastic clips that holds it in place under the dash top panel. I am guessing its for a rear speaker too.
1969 Lemans vert, matador red, 462 CI, 3.07 12-bolt posi
1974 455 TA, admiralty blue/red interior HPP "cover car" - sold
"The best way to show a car is to drive it"
Old 07-14-2010, 10:33 PM
paint guy paint guy is offline
Try ClassicCarwiring.com for a color-coded schematic for your car.
Old 07-15-2010, 08:15 AM
Rastoy's Avatar
I just ordered it from them. Thanks for the link.
