Old 08-06-2010, 08:16 PM
Forrest's Avatar
Forrest Forrest is offline
I remember the 60s Sunoco 260 fuel being 102 or 104 octane and the 280 Sunoco fuel being around 108-110 octane. Course this was leaded fuel too. And that was a RESEARCH Octane Number
Info:
"A numerical representation of the ability of a fuel to resist knocking when ignited in the cylinder of an internal-combustion engine. The octane number of a given fuel is determined by comparing the amount of knocking that fuel causes when combusted with the amount of knocking caused by two standard reference fuels, isooctane (which resists knocking and has an octane number of 100) and heptane (which causes knocking and has an octane number of 0). The octane number is then assigned as the percentage of isooctane required in a blend with normal heptane to match the knocking behavior of the fuel being tested."
Tom Vaught
Yep, I worked at a sunoco station in Miami Fla. back in '74-75, Had the sunoco "280" the pumps had the dial that you could choose 280 down to 210 or something... I remember we used to go out and find the Cadillacs or big Lincolns and siphon/steal (late at night) the gas out of them ( we would smell the inlet to make sure it was the "purple stuff"!) for my 1970 gto with 12 1/2 to 1 compression "pop up pistons"! We knew that the "rich" people used the 280 in their big cars then! I was only 18 and didn't know better.. yea I did some wrong things when I was young.. I remember my '70 goat got a dead battery one night and the girls i was with went out and "borrowed" a battery from someone down the street so we could go out and DISCO! Ha!
  #42
Old 08-06-2010, 08:19 PM
ITSBACK's Avatar
ITSBACK ITSBACK is offline
I grew up in Long Island when I had my first goat back in 1986 and we used to treat our cars to CAM 2 which was 110 octane and purple.
  #43
Old 08-06-2010, 08:23 PM
Forrest's Avatar
For some reason I'm thinking that the sunoco 280 was 112 octane? Am I wrong?
  #44
Old 08-07-2010, 10:34 AM
66GTO Jim's Avatar
66GTO Jim 66GTO Jim is offline
I worked at a SOHIO Gas Station (Standard Oil of Ohio) in 1966 and 1967. Our premium was called Boron and it was about $0.32 a gallon. Sunoco 260 was about $0.35 a gallon then. Sunoco had a dial from 190 (cheap) to 260 and about 4 grades in between. We only had two grades of gas, Extron (regular) and Boron (premium).
The real old timers will get a kick out of this one. Back in the 60s, the customer was truly KING. A customer pulled in and told me abruptly to "FILL IT UP WITH ETHYL". Being 16 years old, I had heard the old term "ethyl" for gasoline but had no idea what it meant. I asked the gentlemen what he meant and he started to get upset, "ETHYL, ETHYL, FILL IT UP WITH ETHYL!!!". Finally, one of my coworkers walked by and said ethyl was Hi-Test (premium to you younger folks). So I grabbed the BORON hose and the guy must not have been familar with SOHIO gas and thought EXTRON was our Hi-Test because the name sounded like it would be. He started yelling "ETHYL NOT REGULAR, ETHYL"! I had to get the manager to explain that Boron was our "ethyl".
When I pumped gas, were wore uniforms embroidered with our name and "MacKeigans Sohio" above the shirt pockets. We were required to ask if they wanted us to check their oil and we always washed their front and rear windows. Mini-skirts were the latest rage so there were some girls with very dirty windshields that took some extra attention. Yes, we had the rubber hoses by the pumps that went "ding ding" when a car ran over them so you knew a customer was there. There were 4 bays with lifts where we did light mechanical work, especially "oil and lube" and we would always have to stop and run out to pump gas no matter what we were doing. The air pump was not only free but we would check the air in their tires and fill them up if they were low.
The best part was I worked evenings after school as part of a "work/school" program as I was taking Automotive as my Major. Many very cool musclecars and hot rods would pull in for gas. Many guys would not let us look under the hood to check the oil, not wanting to give up their "secrets". The night managers girlfriend had a midnight blue 65 GTO Tri-Power 4 speed. She came back and gave me a big hug after I did a mini-tuneup on her car. She told me she could once again go around a corner and not downshift out of 4th! I can still smell her perfume from that hug. The musclecar era of the 60s were a great time to be a teenager with "wheels". Jim
"Never try to teach a pig to sing. It's a waste of time and it annoys the pig"
  #45
Old 08-07-2010, 02:49 PM
lust4speed's Avatar
I worked at a Shell station that didn't have the auto shutoff nozzles - had to stand there and hopefully listen for the gas starting to bubble up into the filler neck. If there was any extra noise around we couldn't tell and the gas would shoot out and usually get us. The nozzles would stay on high and spew gasoline everywhere until it was clicked off manually. It was a very happy day for us pump jockeys when the owner finally broke down and purchased the new nozzles.
Mick Batson
  #46
Old 08-07-2010, 03:44 PM
Coach's Avatar
Coach Coach is offline
I worked at a Shell the summer of 1970 as a gas jockey. You would hear the ding, run, not walk, out to the pump, get the gas started and then ask if you could check the fluids, tires, and clean the windshield.
If you did a really good job you might get a 50 cent tip out of the driver. Over the course of a night the tips alone could get you enough to take a date out to a movie and a malted.
Man life really was simpler back then!
Sold - 1967 Grand Prix Convertible ( http://forums.performanceyears.com/f...d.php?t=639110 )
2003 Bonneville coupe (hers)
2007 Avalanche LTZ 4x4
  #47
Old 08-07-2010, 05:05 PM
My442 My442 is offline
Don't forget S&H Green Stamps, free drinking glasses, and steak knives.....
Always had give-a-ways to bring more people in.
  #48
Old 08-07-2010, 05:25 PM
Kitch428m21's Avatar
Kitch428m21 Kitch428m21 is offline
......and the NEHI soda machine out front which cost a dime and slide the bottle out on 'tracks'
In the first 2 bays at the Atlantic station where I always hung out, the two guys who worked there had a "Heavy Chevy" and a "GT37" because they told me they couldn't afford the insurance or payments for the real deals.
For the first time at that time I started seeing 'no lead' gasoline labels on the pumps ('71)
...and one last thing to humor our younger crowd here, their most expensive car battery was $27.
I thought that was highway robbery. lol
1970 Burgundy GTO hardtop. CVMS built 455 4sp.
May the Torque be with you!
John.
  #49
Old 08-07-2010, 09:42 PM
milkcrateracing's Avatar
milkcrateracing milkcrateracing is offline
I still have about 15 or twenty each of the Shell States of the Union and Presidential bronze coin sets. I broke all my drinking glasses.
Don Hayden <[email protected]>
68 GTO, 70 Tempest Wagon, Two GMC's, a caddy & the FULMNTE
  #50
Old 08-08-2010, 09:42 AM
ERIC AULL ERIC AULL is offline
When i was little (early 60's), my father filled up at the SINCLAIR station "up on the corner". The guy new his name. They used to give out bars of soap shaped like green dinosaurs. That was the company logo......I will never forget fighting with my brother and sister over whose turn it was to keep the soap! I also still have a "Simon Bar Sinister" glass from a gas station....CITGO maybe. I also remember collecting STP stickers to put on our school books. And of course the after school "full service" job pumping gas. The boss didn't pay much but after the shop closed, you were allowed to bring your car in and work on it. Part of your job was to clean the shop before closing, so the day mechanics (gods) could go to work. Thanks Carl,Joe and Benny where ever you are! Eric
