Are there any taller 17 inch tires?
I have 275/40-17 that are 25.6 inches tall. They are the Nitto's NT05. I like these tires but I would like to try taller side walls. Every sticky tire I see is for the 15 in rim. Anybody know of any stickys for a 17 with some sidewall?
'68 Firebird -Before you press that thing to the floor, be sure you're right with God.... '68 hard blocked forged 463 (thanks Luhn Performance), SD prepped HO aluminum intake, SD Perf 290cfm KRE'S,'Ol Faithful cam, 2004r with a "Jim Hand special" converter to a 3.42 Trutrac 12 bolt hung from a 4 link. With a 120 shot of N2O for fun. |
M/T has a 295/45 but it's going to take a BFH to fit in stock wheel wells.
M&H, Falken, and Nitto (NT 450) have a 275/50 but that might be way too tall. I think a 275/45R17 would be the perfect size, but good luck finding any.
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman |
Kuhmo has a 255/50-17 and a 285/40-17. The former is 27" and the later is 26". I'm running a 255/65-17 on my Santa Fe but it's 30" tall. There are drag radials out there in 275/50-17 and they are 27.8" tall.
Stewart
1976 TA, nose converted to 1970 style, 406, ported #13 Heads, '70 iron intake without crossovers, Q-Jet - Cliff style, RARE OS manifolds, Pypes duals w/crossflow, UD 230/238 custom HR 4/7 swap cam with solid roller lifters , Hydro-Boost 4-wheel discs, 4 Speed, 3.23 posi. “Nothing in life is so exhilarating as to be shot at without result.” - Winston Churchill |
I have some Y.O. 17" snowflakes I am gonna use on my 77 T.A. and found the best size for me is a combo they used on the mid 90s Corvettes, 255/45/17 on the front and 285/40/17 on the back. The fronts are 26.1" X 10" wide and the backs are 26" X 11.2" wide. I am probably gonna go with Nitto 555s, but I am pretty sure you can get them in that size combo in Cooper zeons, Kumho ecstas,and firestone firehawks too.
I went with centerline wheels. 17x9.5 with 4.5 BS out back and 17x7 with 3.5 BS up front. I went M&H 325/45/17 out back, 225/60/17 up front. I am 28" tall in the back and about 27.5 or so up front I think.
1979 Trans-Am. 3900 + lbs. 3.42 gear, 10" 4000+ Continental, 280 cfm e heads, performer rpm, 750 Holley, 242/248 HR cam, 10.2 to 1, 11.31, 117.2 mph, 1.49 60'. |
Falken, Nitto and M&H all make a 275/50-17 tire that are 27-28" tall. I run the M&H drag radials on 17"x8" rims on my car. M&H also makes several other tall drag radials for 17" and 18" wheels.
http://www.mandhtires.com/store.php?...mode=cat_click
1967 Firebird ragtop, 464, Weiand 8-71, ported 6H heads, Hyd roller, 4L80E, paddle shifter, Moser 9", Cal-Tracs, Vintage Air, Corbeau seats, 13"/12" disk brakes, Hydraboost, electric cutouts and M&H drag radials. |
