Old 08-23-2010, 03:41 PM
Coach's Avatar
Coach Coach is offline
Default Name That Clunk
Ok this is driving me crazy. My '67 GP was a total basket case when I brought it home. I have been over every square inch of the car when I built it and I thought I had it all right.
Here is the issue I am having. When I do anything that heavily shifts the weight on the front suspension I am getting a clunk out of the front end. This includes accelerating, backing out of acceleration, or hitting the breaks.
It almost sounds like something is binding and then releasing. I have checked the A-arms, and all the moving parts and cannot find anything loose. The steering has no noticeable slop in it, and when it "clunks" it does not seem to change the handling at all.
I thought maybe motor mounts, but those look OK. I thought maybe my exhaust but it sounds like it is coming from the front end, not under the car. Without a lift this is really a pain in the butt to diagnose.
One thing I was wondering about, if I did not get the springs in the pockets correctly, could that be causing the sound?
If anyone has any ideas I would really appreciate it. If I cannot figure it out this week I will have to take it into an alignment shop and I really dread leaving the car with someone who will have to "test drive" it.
Thanks in advance, -Harry
PS: In case I don't find anything do any of you Chicago area guys have a front end shop you would recommend?
Sold - 1967 Grand Prix Convertible ( http://forums.performanceyears.com/f...d.php?t=639110 )
2003 Bonneville coupe (hers)
2007 Avalanche LTZ 4x4
Old 08-23-2010, 05:08 PM
ryan389 ryan389 is offline
I had this problem with a 67 gto i had, I found it was the springs that was not properly installed in the pocket, drove me crazy!
Does it do it going left and right?
Check the springs.
Hope this helps.
Old 08-23-2010, 08:17 PM
PMDRACER's Avatar
PMDRACER PMDRACER is offline
On a buddy's '68 GTO, he had the same thing. Ended up being a lower ball joint rocking in the lower a-arm.
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same.
-RONALD REAGAN
462 cid/ 6x-4/ TH400/ 3.36:1/ 28x10.5/ 3880#/ 12.35 @ 109.36/ 1.69 60 ft/ 4 wheel disc brakes/ 15 mpg
Old 08-23-2010, 08:58 PM
Coach's Avatar
Thanks guys, I'll double check the ball joint, but they are new and I am pretty sure I got them in correctly. The springs I am not so sure of.
Can someone tell me how to get them set in the pocket correctly?
Best, Harry
Old 08-23-2010, 11:55 PM
GStage1's Avatar
GStage1 GStage1 is offline
The springs get seated in the lower A-arms with the end just before the oblong hole in the A-arm.
Had the same knocking/clunking sound on 2 of my A-body cars and one in my 84 Silverado.......all of them had the same problem....bad lower ball joints....one was new and only had 5 miles on it before I had to pull it out and swap it.
George Nenadovich
Buick Performance Club Founder
www.BuickPerformanceClub.com
Old 08-24-2010, 06:31 AM
Charlie Brengun's Avatar
Charlie Brengun Charlie Brengun is offline
I had a loud clunk like that in my '73 caddy. same symptoms as you had, had a friend sit in the car and turn the steering wheel full lock to full lock and you could see movement on one of the upper a-arms.
Turned out it was the bolt that holds the upper a-arm to the frame that was worn out so I had a shop fix it for me and that solved the problem. So perhaps have a look at the a-arms..
1968 - Pontiac GTO
Old 08-24-2010, 09:47 AM
Coach's Avatar
Again, I appreciate the feedback. I had my wife turn the wheel stop-to-stop with the front end in the air and saw no flex in anything. I have replaced all the bushings and such on the front end, that's not to say I might not have screwed it up or gotten a bad component.
This weekend I will get into the springs and see if I have them set correctly in the lower pocket. Any tips on how to check the ball joints while the car is jacked up?
Thanks,
Harry
Old 09-01-2010, 10:22 AM
Coach's Avatar
Well I wanted to bring this one full circle.
Lessons learned:
1) Sound travels - when sitting in the drivers seat, that clunk you hear from the right front wheel could be coming from anywhere in the car.
2) When you deliberately leave a set of bolts loose during a multi-year restoration, TAG THEM. Use anything you need to, but put a note on there reminding you to look at them in 3 or 4 years when you button up the project.
3) When trying to find a loose suspension component, it is MUCH easier to do it on a four post, drive up lift, then it is laying on your back with the suspension hanging in the air.
I finally broke down and took the car over to a friend's garage, he got in the passenger's seat hung his head over the side of the car and said it sounded like the noise was coming from the rear of the car, not the front. We got it up on his four post lift and sure enough when we started to bounce it up and down I could see the bolts shifting on the rear end struts. I now remember not torquing them down as I was thinking about swapping out rear ends and didn't want to fight them later. We spent 20 minutes going over every bolt on the suspension and motor/trans mounts, these seem to be the only ones I left loose.
The car is now silent to drive, the "looseness" is gone on the road, and life is good. Well pretty good, the voltage regulator when wacko on the ride home, so I have to figure that one out, but at least I can drive the car without wondering if the whole front end is going to fall off!
Again, thanks for all the support,
Harry
Old 09-01-2010, 01:18 PM
Boy Harry, you now have me nervous. #2 is something I SHOULD have done.
Oh well, you found the problem, fixed it for no additional $$ and taught me a lesson at the same time!!!!
Thank you Sir!!!
Matt
71 LeMans Sport Convertible
04 Pulse Red GTO A4
10 GMC Sierra 1500
Old 08-13-2011, 03:10 PM
schlitzman's Avatar
schlitzman schlitzman is offline
I have a similar situation to that of Coach. I have a '67 GP convert. Had it now a year and this horrible "clunk" sound developed. Seemed to coincide with my upgrade to a 1.25" front sway bar. First I thought it might be the end links. No, it wasn't. I've isolated the sway bar, shocks, tightened all bolts and motor and body mounts and can't find the source. The sound occurs usually at low speed when the car weight shifts, like going up/down a drive way or making a low speed turn. It sounds like the front springs are "catching" and releasing. Driving me crazy.
I'll bring to my suspension mechanic and ask him to reseat the springs. Can I use a rubber hose as an isolator? I will also check all bolts in the rear, too. Only ones left. Any help or advice would be most appreciated.
Coach, thanks for your initial description. Very helpful. Also nice to know I'm not alone with this problem. Sometimes you think you're going nuts.
Regards,
Schlitzman
Old 08-13-2011, 03:32 PM
Pontirag Pontirag is offline
Name that clunk
lets call it PITA
Old 08-14-2011, 02:46 AM
PMDRACER's Avatar
Make sure it's not the upper arms shifting because the bolts for the shim are loose.
-RONALD REAGAN
Old 08-14-2011, 08:08 PM
HaloMedic's Avatar
HaloMedic HaloMedic is offline
Or missing shims I had a clunk in the front that i chased for a year , turned out it was missing a few shims
Gentlemen put your trust in God, But mind to keep your Powder dry. Oliver Cromwell
Michael Hughes Sr
1966 GTO Convertable: Stolen never recovered
1966 GTO Hard Top .30 over 455 4-Speed 3:23 Posi
Old 08-14-2011, 08:14 PM
Evil Stu's Avatar
Evil Stu Evil Stu is offline
Front coils have a top and a bottom. If you install them upside down you get a loud click/clunk sound when the front suspension travels.
Stu
"Having a 10 second Civic must be just like coming out of the closet; you'll surprise some people, but you're still gay"
1970 GTO, 455+.034", 0 deck, Wiseco's, Eagle rods, 60919, Rhoads, E-Heads, 1.65 Scorpions, RPM, Custom Qjet by Cliff, Doug's 1 7/8", THM 400, Gear Vendors OD, 3.55s.........Her name is Blandorf; after a girl I knew once, 'cause she's just Bitchin, always.
Old 08-15-2011, 11:51 AM
schlitzman's Avatar
Thanks, Stu,
How do I tell the difference between the spring top and bottom? Also, can I install an insulator, like neoprene or Tygon tubing?
Thanks for the info.
Bruce
Old 08-15-2011, 10:30 PM
IOWA552SLOW IOWA552SLOW is offline
just got done fighting a similar noise in my lemans. ball joints less than 2 years old, tie rods as well. i did find worn control arm bushings, and a weak lwr ball joint as well. i did replace those parts as well as everything else in the steering. i agree with all of the advice everybody else has to offer, check bolts and maybe even the new parts, could be bad out of the box.
Old 08-16-2011, 11:21 AM
Evil Stu's Avatar
Originally Posted by schlitzman View Post
Thanks, Stu,
Bruce
I don't know. I put mine in wrong and had an awful noise. Somebody told me what I told you, so I changed 'em and now they're quiet.
Stu
Old 08-16-2011, 05:10 PM
schlitzman's Avatar
Silence, at last!!!!!
Finally found the problem after three days of trial and experiments. I would eliminate or isolate a function stepwise so I could check out the systems and actually find out what caused the "clunk".
It was the TH400 transmission cover. It was not properly seated and would catch on the front mount every time the car would flex.
I did find out the springs were properly installed and aligned. My wheel bearing were in bad need of service. Body mounts were all torques to spec. Rear sway bar needed tightening, but wasn't loose. Exhaust and header bolts needed retightening.
The advice from all of you was very helpful and useful. Thanks much. Hope my experience helps others, too.
Schlitzman
Old 08-18-2011, 07:57 PM
Silver Judge's Avatar
Originally Posted by Coach View Post
Lessons learned:
It's good to have the clunk gone I bet !
Do you mean the rear shock mounts? I'm confused by what you mean when you use the word struts
501 HP, 554 ft lbs TQ
Old 08-28-2011, 09:27 PM
Wild Bill Wild Bill is offline
Thanks, Stu,
Bruce
the top of the spring is ground flat and sits inside the frame.
the bottom coil is just cut and sits with the cut end in the "step" formed in the LCA
