Those numbers at just FOUR lbs boost should clue you in on the potential. IMO there is more than enough under hood to go well below 9's ON pump gas. Actually glad he plans to turn it up a bit at a time. Good plan.
There should be at LEAST 1600 hp at 15 psi on a conservative tune if the turbo can supply enough air. A whole bunch more if intercooled. Yeah he's going to have his work cut out to get that power to the pavement. |
Rob, here are a couple of shots I took with the digital camera....
69 'Blackbird' 535 CID IA II SD Wide Port E-head Pro Systems Dominator |
Thanks Paul for getting my best "side".
DOC'S TA Turbo 535, CV 1 heads. Built by Cerralli Competition Engines Tenth Anniversary (Van Nuys) restored. Tenth Anniversary Barn Find (Norwood) Both 4 speeds! |
Yes - one Kick-Butt T/A -Pontiac power !!!! .
The Bandit Rules - Make mine with a SD-455 Engine . |
Congrats Doc!
That's awesome for first outing at this boost level. You have potential to go easy 8's with your combo at some nice conservative boost levels and even on pump gas. How did the tune feel like? What a/f readings did you get through the run? Sounds and looks great from the video, looks like you had a rich mixture in it, smart move. Kris |
better send in the time slip -- or it dont count BWAAAAAAAAAA - good job are you running a boost controller ??
Ran it rich and then started jetting it. Went from 11.5 through 13.0.
cgeise- Running an AMS-1000. Had it programmed to run off the gate only during the license runs.
I am sure he will when it counts.....Rules are Rules.....Did you send your time slip yet...
be safe - -remember those turbo cars like it a little rich
Mark,
Watched that video in your sig again. Love the way your car launches! Music is perfect for it as well. Rich is always better I agree.
Nope - he can bite me - I sit here with on my desk and look at it almost every day , just because I can
LOL that's funny ..
Doc ,your off to a good start,call me ,we have a track rental on Fri, Oct 29, at island ,track will be sprayed half way .Bill C.
Checkered Flag Machine & Ceralli Competition Engines Racing engines and induction development http://www.checkeredflagmachine.net/ |
Tom Vaught
What are you thinking for suspension changes with the mini tub?
Cal Tracs 4 link Ladder bar
68 Firebird Are you running with the wind or breaking it? |
I think there tons of power there to run 8's but is the car up to the task.I mean safety wise..cars that heavy need a special cage I think its 25.3 tag.A bonsai run into 8's would be great for bragging rights but not very practical.Then there stopping all that weight at 160 mph plus..just something to think about.
Tom I couldnt remember what turbo.(Thats why I stated IF the turbo can supply the air) I do know with his CV1 heads if he sees 15 psi on the gage there will be a LOT of pounds of air flow. I've forgot his flow numbers but thinkin around 400+ cfm. Conservative guesstimate 1600+hp at @15 psi on the boost gage. Heck a 270 cfm head at 15 psi can support 1000+ with the right turbo and intercooled.
#38
How heavy is this car? I've seen lots of 2nd gens deep in the 8's and in the 7's as well. More tire would be nice, but setup properly a small tire caltrac car can put down some serious hp with a drag radial... Lots of guys doing it in the 7's and 8's - some faster yet! Best of luck with it!
The secret to happiness is not getting what you want but rather, wanting what you have. |
#39
Got me seriously thinking about a turbo doc...
