Old 11-08-2010, 02:17 PM
Few tidbits:
-Air cleaner is correct for 4bbl non 428 (370 and 390 hp 428's used a single snorkel chrome lid assembly like a 69 Firebird 400 or a 68 GTO)
-While other 69 Pontiacs had the option of a rear defogger (blower) GP's had only the rear defroster (grid) as an option. You could not order a defogger from the factory on a 69 GP and you couldn't order a grid defroster on any 69 except a GP
-Like the 69 GTO, 69 GP's came with standard manual drum brakes and Power disc were optional. Manual disc was no longer optional on any 69 Pontiacs and power drums while optional on some other Pontiac's in 69 they were not optional on GP's
-manual shift GP's came standard with walnut shift knobs and 4spd models used a knob unique to the GP (different looking bezel similar to later Firebird knobs), I am not sure if the 3spd manual GP used the regular woodknob used on A and F bodies (with a large pontiac arrowhead and no shift pattern in the bezel) or had a unique GP version like the 4 speed.
Anybody know for sure? this is the first 3pd GP I ever saw, I'll try to look it up in my 1970 MPC.
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
  #42
Old 11-08-2010, 02:19 PM
Also I wonder if the car has the rear frame braces you see on manual trans 69 GTO's (except convertibles)?
1969 Bonnie Cvt
  #43
Old 11-08-2010, 02:20 PM
Engine-Ear's Avatar
Thanks, N.
  #44
Old 11-08-2010, 08:07 PM
There's a red 69 3 spd car that shows up at Norwalk every yr. It's a no console car IIRC and is unrestored.
Mike
former." --Albert Einstein
- Winston Churchill
  #45
Old 11-08-2010, 10:15 PM
se428bandit's Avatar
se428bandit se428bandit is offline
Matt, That is a cool GP. When you want to add gauges 70-71 A-body's are the same.Here are some pics of a '69 GP with a hood tach.
ID:	223915   Click image for larger version
  #46
Old 11-08-2010, 11:05 PM
428ho4spd's Avatar
428ho4spd 428ho4spd is offline
Originally Posted by Engine-Ear View Post
Coming soon, gents. I have the 'numbers' carb for this car...I just need to go thru it.
Upon further inspection, the pump seems to be leaking from the O-Ring. I will probably rehab this one and hopefully I didn't wreck it on the ride home (whereby I ran the pump nearly dry).
I've seen a few of those pumps where the tack-welded return pipe at the housing was broken loose and caused a big leak. I have two spare original '69 pumps, if you need one let me know.
Grant
  #47
Old 11-08-2010, 11:22 PM
428ho4spd's Avatar
Few tidbits:
John,
The GP 3-speed knob was a walnut knob like you described, it has a red center with the Pontiac Arrowhead and read... Pontiac Motor Division around the perimeter. I'll attach a picture of one in another factory 3-speed car. By the way, this particular GP is the most basic GP I've ever seen... manual drum brakes, std hubcaps and radio delete. I cant see one option that would have been listed on the PHS invoice of this car... maybe a tinted windshield?
Grant
ID:	223918   Click image for larger version
  #48
Old 11-08-2010, 11:25 PM
428ho4spd's Avatar
Good question... 4-speed GP's do have the braces, I'm sure the 3-speed cars do as well. By the way... the '69 428HO auto cars have them as well.
Grant
  #49
Old 11-09-2010, 07:11 AM
GpFreak's Avatar
GpFreak GpFreak is offline
Arrow
I've never seen one with a radio delete... rare.
Steve Naresky
  #50
Old 11-09-2010, 10:13 AM
Engine-Ear's Avatar
re: gauges, thanks for the app range. I certainly want instrumentation at some point.
re: hood tach, I'll probably cut the hole and go that route.
  #51
Old 11-09-2010, 10:14 AM
Engine-Ear's Avatar
X2. Man, that IS a stripper.
  #52
Old 11-09-2010, 10:54 PM
428ho4spd's Avatar
Keep in mind that the GP gauges use different housings with attached green lenses at the bulb socket holes which give it a unique green illumination while the A body gauges lite-up white.
Grant
  #53
Old 11-09-2010, 11:58 PM
Engine-Ear's Avatar
Good to know!! Well, first things first...I need to patch some minor holes in the floors, thanks to vynil roof rot-out. Meanwhile I'll shift by ear (I have an ear for engines) and listen for lifter clatter.
  #54
Old 11-10-2010, 11:00 AM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
Matt I had a 70 GP SJ set of Rally Gauges with Clock but sold it a while back. Sorry
Your harness will need to be changed to match anyway though. Just do under dash old school , its easier
63 Catalina coupe 467 cid budget drag car 11's 1/4 , 7.3 1/8th pump gas n/a
66 Star Chief Executive 57k mile
69 Le Mans 2 dr HT 350 85k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 101k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2007 Hummer H3 3.7 liter turd
2019 Chevy Spark petrol car 38 mpg
  #55
Old 11-11-2010, 02:33 PM
Engine-Ear's Avatar
Default leaky no moe
Sounds good, Larry. I have spare underdash gauge sets anyway.
Anyway, just a quick update- I eliminated the power steering leak. The OE pump's o-ring has an obvious compromise. I had a spare '69 P/S pump from a 50k mile Bonneville I parted out...impact wrenched the nut off the front (a locking nut, btw) and used a light duty gear puller to extract the pulley...swapped pulley then gets reattached by impacting the nut back on.
...oh and in true engine-ear fashion, I overfilled the power steering pump and found another big mess under the hood after I took it for a beat run. I guess some rolled up paper towels will be used to siphon out the excess.
Also snugged down the carb and replaced two missing intake bolts...seriously! The pass side rear two intake-to-head bolts were gone! Gee, not too much potential for a vacuum leak THERE, eh??
...We now return you to your regularly-scheduled forum...
  #56
Old 11-11-2010, 05:10 PM
74 SD455 Formula 74 SD455 Formula is offline
Originally Posted by 428ho4spd View Post
John,
Grant
I would have liked to have seen the Window sticker to that car as it's always been my understanding is that disc brake's where standard on G.P's in 69. My old 69 3spd G.P. is still running around in Illinois and that was a 2 option car coming out of California. one of the option's was tire size and the other we never did figure out,but was a $10.00 cost. The 2 cpmbined were $26.00 in total.The car was a White G.P. with a Blue Interior,AM radio,power sterring and brakes.3spd Manual open rear end and NO console.The window sticker on mine showed the power steering and power brakes to be standard options as well as the AM radio.
  #57
Old 11-11-2010, 10:54 PM
428ho4spd's Avatar
Yes, me too! I've heard that later in the production year disc brakes became standard on all '69 GP's. Some early '69s may have been shipped without disc brakes due to some confusion on the order form... see attached bulletins. Not sure about power steering though, every invoice I've seen shows power steering listed as an option. The $10.00 cost listed was most likely the advertising assistance charge for those dealers that participated in the program. Do you still have a copy of that window sticker? The console was standard on GP, with buckets of course. That's interesting... I've never seen a bucket car without one. I'm wondering if your car had a group package option ordered that gave it those options? It should have been listed either way.
ID:	224272   Click image for larger version
  #58
Old 11-11-2010, 10:55 PM
Engine-Ear's Avatar
74 SD455 Formula, see earlier post re: brakes. also, it's my understanding that floor shift '69 GPs came standard with a console. Your $10 option sounds like it may be the export option, like on mine.
...man I am sure glad to own this car. ...and to think that there were people who were telling the guy I got it from that I shouldn't have it.
  #59
Old 11-12-2010, 10:59 AM
Years ago I tried to buy a 69 stick Prix with a Bench seat floor shift. Only one I'd ever seen and supposedly not available.Car was Expresso Brown and had rally wheels. Very low option car.
Mike
- Winston Churchill
  #60
Old 11-13-2010, 12:47 AM
428ho4spd's Avatar
Mike, do you remember if it was a 3 or 4-speed? Now that would be cool! I wouldn't be surprised if a few slipped through being ordered with a bench seat and no trans option checked off... just the standard equipment 3-speed on the floor.
Grant
