#361
85 87 91 here.
But there is a couple of stations that sell 100 out of the pump!
68 Firebird Are you running with the wind or breaking it? |
#362
I remember when I could buy Sunoco-94 for a few pennies over $1.00 per gallon and you could still get 89 leaded for under $1.00.....and then the Exxon Valdez was shoved onto the rocks.
WEARS GACH?
#363
I was going to say the same thing John...
69 'Blackbird' 535 CID IA II SD Wide Port E-head Pro Systems Dominator |
#364
In the 60's you could buy 100+ for 25-30 cents!
#365
1965 - 1966....gas wars in Wichita, KS. You could purchase "Ethyl" for $0.15 - $0.17 a gallon.
Due to the current economic conditions...the light at the end of the tunnel has been turned off. Meet you at the finish line.....don't be late! |
#366
2 passes if possible?
If he can only get one pass that works, but if he doesn't get booted I can't see any good reason why someone wouldn't make another pass. Hell, he might even lay down a better number on the second run. Wouldn't that show the 'posses'?
#367
He's been quiet of late, but he's lurking. WEARS GACH?
#368
gachites
mite have to start a straw poll... gooberites and posses |
#369
The good people of Mayberry might have to form a posses to hunt down goober or gomer gach and make sure he ain't chetin, runin some monshien in dat car of his.
The pile famlee wold be ashamd to B assosiated with chetin....................
Brad Yost 1973 T/A (SOLD) 2005 GTO 1984 Grand Prix 100% Pontiacs in my driveway!!! What's in your driveway? If you don't take some of the RACETRACK home with you, Ya got cheated |
#370
If Gooch does not show can he be banned for a month or two?
First Pontiac powered street car in the 7's 7.940@170.84. 3460#s |
#371
I think I hear crickets. What are you up to goober?? Trying to figure out how to get your junk to run...during the day...with Pontiac racers around??
#372
A little up date for the posse...the cage is suppose to be done by next Wed, which is 24. The frame is being notch..so I can get the Diaper in. The side kick on the pan hits the frame on pass side..when I put the diaper on the motor then into the car.. I can't pull the diaper up because its wedge between the pan and frame. He's going to take out and inch that should give me plenty of clearance. No more diaper problems, and now I should be able to pull it down in the back to change the oil. He promise me by the Nov, 24.
Here's a picture of what has to be added for the car to certify for 8.50's. Kevin ( from Atco )told me they could inspect my car and give me a 90 day certification..Maybe I can even get my licence same day. I think this guy is a little high on doing the cage...the black out areas in the picture is whats already there, the white tubing is what he has to add. $1100.00 bucks...I figured $650.00 would be the most...but he's doing it on short notice. Last edited by Gach; 11-18-2010 at 10:22 PM. |
#373
You might as well get the runs in for the license. You need six runs total. Really easy at arent day.
Kevins a good guy at Atco. Real accomodating.
DOC'S TA Turbo 535, CV 1 heads. Built by Cerralli Competition Engines Tenth Anniversary (Van Nuys) restored. Tenth Anniversary Barn Find (Norwood) Both 4 speeds! |
#374
Motor is already to go in as soon as the cage gets done...just have to make up a few brackets...If you look at the first picture on the kick out you can see where it's hitting the frame.
#375
He's a super nice guy..him offering to give me a 90 temporary is nice. Now I can let that mother eat. I think I got the chassis figure out made some changes, the cage guy is going to scale the car from me too. Also gave me a bunch of tips..he's also putting in the stops in the front end. He figures keeping the front end from wheel standing is worth a couple of tenths. I guess we'll find out.
#376
Any particular reason that you're showing us the 'spacer plate'??
#377
A plumber would just used galvanized and some elbows, and unions and put that cage together yerself and save some money.
#378
I think it's a little high too. I paid $1500 for everything in your picture, (single rear down bars) in Chromoly.
Looks like it's coming together nicely. |
#379
Son...that's not a spacer plate....LOL that's a two stage nitrous plate.
#380
Na, this is a two stage nitrous plate! |
Closed Thread |
