Might be less work to fit a repo than to repair yours. Only one way to find out.
1964 GTO 501, Edelbrock Heads NA, 3460 lbs. 9.76 @ 137mph 1971 Trans Am Lucy Blue, 11.56 @ 115 1966 LeMans. 6.0L LS single turbo, 8.85 @155 mph 1976 Trans Am twin turbo 462, SD Edelbrock heads 8.03@171 mph 2009 G8 GT |
Originals have a date code stamped in fender to hood jamb. Re-pops don't, that is one give-away. We have used many pairs of the re-pops at our shop, and have seen no improvement in the tooling over the years. Some customers insist they want 'new' = chinese junk fenders. I would recommend profesional instalation of the re-pops. Personally I prefer to patch a small softball size hole anyday! Scott
68pongto, Since you are familiar with the re-pops what is the biggest problem with them. I've heard that the contour above the wheel "eyebrow" is not correct and you can tell by reflected items in it when its along side a car with original fenders. Also that they use thinner metal than original.
Curious on what you may have run into? |
