Old 12-06-2010, 09:57 PM
65nss4spdGTO's Avatar
65nss4spdGTO 65nss4spdGTO is offline
Default BME
500 series BME's at the same length, 6.700" are about 40g lighter then the 396 series from the comparisons I've had over the past few weeks.
Calvin Hill
Hill Performance
708-250-7420
Old 12-08-2010, 01:58 AM
jotrout jotrout is offline
40 gm's, that huge. Good info
Joe
Old 12-08-2010, 09:11 AM
J.C.you's Avatar
J.C.you J.C.you is offline
Post re: roundy rounder with aluminum rods
Originally Posted by Elarson View Post
Fatigue life of aluminum is a function of the stress level and the number of cycles at that stress. If the stress level is low (such as in street use), they'll live practically forever. It's when the stress is high that they have limited life (big HP, big rpm). About the only thing they're not good for at all is NASCAR-type racing. At 9000+ rpm with the foot to the floor, they would not survive a 500 mile race.
Eric
I was leaning on using a BM rod next season in a circle track application. I called and talked to Bill to pick his thoughts. He said they had mixed results. He did not recommend a aluminum rod in that type of racing where you go wide open, then let off repeatedly.
In a drag race app i have over 100 passes +dyno time on a set of 426 series rods at 1000+ hp. This series rod can take much more hp than this.
Eric, what series rod do you use?
Old 12-10-2010, 01:14 PM
joes455 joes455 is offline
Just curious how much do these rods weigh?
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119
Old 12-11-2010, 03:41 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
BME rods (396s) in my hemi have around 200 runs on them. A "run" is up to 20 seconds long in mini-rod pulling. I see them going "forever", with only 3.75" stroke, no more than 9,000 RPM, and probably a little shy of 1,000 HP.
