Old 01-17-2011, 11:10 AM
Hotrodizz Hotrodizz is offline
Went to the body shop, making some progress I guess. Undercarriage is painted, they want me to bring the subframe so they can get it on the ground and align the panels. I am supposed to get the painted shell back within 2 weeks.
  #62
Old 01-17-2011, 01:08 PM
Bustd Knuckles Bustd Knuckles is offline
Default Emergency brake paint
Great work on the resto ! the pictures are super and a great reference. What is the paint type and color for the Emergency brake assembly ? I think I saw you use it on various interior hard parts. Keep up the good work !
  #63
Old 01-17-2011, 01:15 PM
Thanks!! I used Semi-gloss black, and Eastwood Cast iron paint on the E-brake.
  #64
Old 01-19-2011, 02:28 AM
cdoggy81's Avatar
cdoggy81 cdoggy81 is offline
Nice
73 TA 4 spd #'s match red/white - "STOLEN" AT TERRY SPEAR's SHOP IN Columbia TN ~mid 2014
Last offical pic of the car can been seen here:
http://clubs.hemmings.com/pontiactn/...%20-%20rev.pdf
People have seen it posted FS on Craigs List back in late 2013 early 2014....
IF YOU HAVE ANY INFO ABOUT IT PLEASE CONTACT ME!!!
  #65
Old 01-19-2011, 03:27 PM
njsteve's Avatar
njsteve njsteve is offline
Lookin good.
I'm having flashbacks to my resto project. :-)
  #66
Old 01-19-2011, 06:50 PM
tommie69's Avatar
tommie69 tommie69 is offline
Originally Posted by Hotrodizz View Post
My coater quoted me $500 to do the subframe, a-arms, core support, bumper support, fenderwells, and any other misc underhood brackets & supports. I thought my 59 Impala complete x-frame for $700 was a bargain a few years back, but this seems even better.
Your not getting half that done on Long Island "NY" for that.I had the rad support,wheel houses done for $400.He wanted $700 just for the sub frame!Great find you have there.Very nice!
  #67
Old 01-20-2011, 03:44 PM
Originally Posted by njsteve View Post
Lookin good.
I hope my car turns out half as nice as yours.
I have had the subframe 80% done for a couple months. Body shop now needs it, so hopefully that means they are aligning panels. All the black parts are powder coated, rest of the items were blasted, then detail painted.
Shaker BEFORE, then after we prepped the base and sent to Norwood for riveting.
  #68
Old 01-20-2011, 03:54 PM
Formulabruce's Avatar
Hope the body shop not only uses the Dowels, but also does a few measurements on that subframe to get it right,straight, could be huge with sheet metal alignment. Bolts at 75-95 ft lbs. I would give them extra washers to be able to lower the rad support to correct spot. Looking great so far! Nice to see a 73 getting this treatment.
" Long may we DRIVE !"
  #69
Old 01-21-2011, 12:43 PM
71firebird400's Avatar
71firebird400 71firebird400 is offline
Wow, what an awesome project! I have two questions for you-
How did you clean up the emergency brake assembly? That looks amazing!
What have you been using to prep the driveshaft/rear axle for paint? Those too look awesome!
Mark
  #70
Old 01-21-2011, 12:49 PM
Thanks!
I sandblasted the E-brake, then tried to duplicate the factory black "line", and instead of leaving the upper part bare metal, I painted it.
I used a wire wheel on the driveshaft, I was going to just clear the bare metal, but ended up painting it.
The 10 bolt was to large for my blaster, so I had the powder coating guy blast it for me.
  #71
Old 01-21-2011, 01:29 PM
Thanks for the replies! I'll be doing some of this stuff myself and I'm currently using a wire brush on an angle grinder but wanted to know how to tackle the bigger stuff. I've got a local outfit that has powder and ceramic coated for me before, so I'll probably use them.
Good luck with the project, it looks amazing!
Mark
  #72
Old 02-03-2011, 06:26 PM
Couple pics the body shop sent today, some progress is better than none I suppose...
ID:	233361   Click image for larger version
ID:	233362   Click image for larger version
ID:	233363   Click image for larger version
  #73
Old 02-04-2011, 07:02 PM
LeighP's Avatar
LeighP LeighP is offline
Looking good!
I did the same with my e brake asembly...sandblasted it, washed it out and painted both the "bare metal" part and the satin black part. Followed the line where the factory had dipped the assembly.
Regards,
Leigh
Pontiacs I’ve owned….
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1951 Chieftain Flat head 6
1967 Firebird 400 convertible
1967 Firebird 400 coupe
1979 Trans Am 403
1971 Formula 455 (clone)
1969 Firebird 350
1968 Firebird 428 manual.
Sydney, Australia
  #74
Old 03-18-2011, 10:55 AM
Been a while since I updated this post. The body shop sent me pics of the painted panels a couple weeks ago, I hear the shell is painted and they are cutting/buffing right now. Ive been trying be patient, staying occupied on other projects as well as restoring parts for this car.
The PUI "red" is to bright for 73, not even in the ballpark, so I am going to take the seats apart, and dye them along with the door upper door panels. Wish me luck..
ID:	238424   Click image for larger version
ID:	238425   Click image for larger version
ID:	238426   Click image for larger version
  #75
Old 03-18-2011, 11:20 AM
Outer A/C box is done. I pretty much just disassembled everything, removed the original sticker with a heat gun, then cleaned, blasted, and repainted all the original parts (other than new blower motor) then reassembled.
I did use aersosol Plastidip to give the pipe gaskets a "new" look, and also cleared any of the cleaned bare metal surfaces. It had crack at the bottom where they beat it up installing headers at some point. One of my buddies fiberglass repaired that for me. I ended up using Duplicolor FB109 to refinish the exterior of the case. It is a dead-on match for the original finish, it blended in perfect.
Name:	2011-03-12 16.31.40.jpg
ID:	238433   Click image for larger version
Name:	2011-03-12 16.31.56.jpg
ID:	238434   Click image for larger version
Name:	2011-03-12 16.32.07.jpg
  #76
Old 03-18-2011, 11:55 AM
Norwood's Avatar
Norwood Norwood is offline
Very nice, can't wait for summer....it will be done?
  #77
Old 03-18-2011, 01:20 PM
I hope.
  #78
Old 03-18-2011, 04:42 PM
Father&Son73T/A Father&Son73T/A is offline
Thumbs up
I can't wait to see this badboy
1973 T/A Buccaneer Red L-75 A3,83k mi. #'s match
1979 T/A Atlantis Blue W-72 WS6 23k mi.survivor#'s match
1999 T/A Navy Blue 60k mi....babied
1968 442-gone but not forgotten
"Oh,you can think about it,.....but don't do it!"
Sheriff Bufford T.Justice
  #79
Old 03-18-2011, 04:53 PM
Seems like I may have the Brewster 73 from the other body shop too. The shell is actually painted.
  #80
Old 03-18-2011, 09:54 PM
Brewster's Avatar
Brewster Brewster is offline
Brewster huh? hope to see that this summer too!
Pictures, Pictures..
