Old 10-19-2010, 12:08 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Originally Posted by Targa View Post
... Like when you have the two rockers next to each other, they shared a shaft...
On a canted-valve head??
  #42
Old 10-19-2010, 12:42 AM
Targa Targa is offline
No. I said that all wrong actually.
I was thinking one thing and typing about another.
  #43
Old 10-19-2010, 08:23 AM
J.C.you's Avatar
J.C.you J.C.you is offline
how is the oil drainback with these heads? It is hard to tell from the pics. My application will be for a circle track modified, so this may be critical for oil issues.
  #44
Old 10-19-2010, 08:30 AM
bankbook's Avatar
bankbook bankbook is offline
Well, trigger has been pulled.
Bought a set from Calvin today.
'Checks in the mail' (tomorrow)...as the saying goes.
Thanks for that heads up for contacting him Tom, I really appreciate that.
Thanks to all the others who chimed in as well.
Joe
Congatulations on buying a great head. No disappointments for sure.
DOC'S TA
Turbo 535, CV 1 heads.
Built by Cerralli Competition Engines
Tenth Anniversary (Van Nuys) restored.
Tenth Anniversary Barn Find (Norwood)
Both 4 speeds!
  #45
Old 10-19-2010, 08:31 AM
bankbook's Avatar
Not an issue so far. Jim stated that he has a set running on that application with no problems at all.
DOC'S TA
Both 4 speeds!
  #46
Old 10-19-2010, 09:09 AM
Sirrotica's Avatar
J.C., It's good to hear your still working on your oval track modified and does anyone know any details about who or what kind of oval track car is using CV1 heads? I might need to call Jim and find out about that because Pontiac powered oval track cars are about scarce as hens teeth. Great to hear others are using the Pontiac engine as I did for quite a few years racing oval tracks and had great success with it. Targa, sorry for the post hijack but I love hearing about Pontiac powered oval cars, now back to your regularly scheduled post.....
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
  #47
Old 10-19-2010, 10:05 AM
7T2 7T2 is offline
1" wide troft for drainback down the middle, and (2) 9/16" drain holes at ends.
  #48
Old 10-19-2010, 11:01 AM
Sirrotica's Avatar
So Jim, who else is using them in an oval track car?
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
  #49
Old 10-19-2010, 11:34 AM
bad69bird's Avatar
bad69bird bad69bird is offline
Drain back is awesome...no issues here and my motor has went to 8800 by accident more than once. I noticed no oil pressure issues.
East Coast Mafia TTFMF
Making CVWHAT's great again. I guess it took a deplorable ECM member to do it!
Originally Posted by Ray Cox View Post
Holly cow we must be some dume corn huskers here in indiana or somthing!!!
Fastest Blow-thru Pontiac powered car in the Country [email protected] (3465lbs)
Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: [email protected]/ [email protected] (3365lbs)
  #50
Old 10-19-2010, 11:41 AM
T Syron's Avatar
T Syron T Syron is offline
Calvin is a great guy to deal with. You won't be disappointed.
Good luck, Tom
  #51
Old 10-19-2010, 09:21 PM
Good luck
x2. You'll be flyin.
  #52
Old 03-02-2011, 06:55 PM
Yella Terra Yella Terra is offline
Default Yella Terra Pontiac Rockers Update
Hi Guys,
Im fairly new to your forum and just wanted to give users an update on some of the Yella Terra Rockers (dont get the wrong idea ...im not promoting them on your forum...just giving you what we will have available for the Pontiac guys).
Ive attatched an image of our Pedestal Mount/Trunnion (6317) rockers that are used for the CV1 heads. These rockers are our registered design that suits BBC/BBF. They come with pedestals and pins and aligning tool to bolt these on. The rockers give you the stability of a shaft system ( no guideplates/hardedned PR/Girdles needed).
We currently have
STUD Systems
YT 6029 Pontiac V8 7/16 1.5 ratio straight arms to suit factory heads Stud system
YT 5010 Pontiac V8 7/16 1.65 Ratio Stud systems
SHAFT SYSTEMS
YT 6370 Pontiac 8 Edelbrock Performer Twin shaft system ( 240” inlet offset & pushrod offset))
YT 6372 Pontiac 8 Edelbrock Performer Twin Shaft system
We are currently developing Bolt on Shaft systems (Platinum Series) similar to the picture attatched to suit
Pontiac 6X Original Cast heads
Pontiac KRE D Port Heads &
Pontiac KRE Hi Ports
These will be released in the next 6-8 weeks(Assuming all the testing goes 100% )
in Australia and we'll post them up on the web and let you know when available in the USA
Most of our products will be available from our US distributor BP - David and his team @ Butler Performance.
If you have any further questions ...just email me at [email protected]
Glad to be part of the community
Jim
Yella Terra
ID:	236399   Click image for larger version
