Old 03-10-2011, 05:17 PM
gto4evr gto4evr is offline
a few issues here. First off, the clutch pedal SHOULD be higher than the brake pedal. Upward travel should be stopped by a rubber bumper on the pedal brackets so first off make sure the bumper is in place. On the other side of the firewall, there should be a spring pulling the Z bar back towards the firewall and a second spring pulling the clutch fork against the Zbar keeping the rod in between under tension from falling out as you describe.
Name:	clutch springs.jpg
