2002 GP stall/surge problem
My 2002 GP has been having a problem, i start it, it drives fine for awhile, then it has a sporadic stall or surge problem, it stalled on me, at idle, while at an ATM. started right back up(no cranking) then it will sporadictly surge while driving, when it's not doing this it drives fine, no "check engine light" no codes found yet, fuel filter was changed a few months ago, don't think it's bad gas, i'm thinking fuel pump?, ignition? mass airflow sensor? 194,000 miles.
I fixed the problem, bad mass airflow sensor!
good
sons 97 GTP was acting up and it was the crank sensor they are fun to change,need to remove the balancer.
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
