Old 04-11-2011, 08:06 PM
mtnbktrek mtnbktrek is offline
Default Need pics on shroud before I call PY tom.!!!
Need pics of fan shroud or specs I just waited months for PY to get me a shroud I pull off fan rad support and drained rad I'm pi$$3d that it's not even close ... No holes drilled I have a 68 lemans conv there. Is a 400 in it and came stock w a 350 I want to make sure im right before I call PY in the morning my rad tank to tank measures 25.5" top to bottom is ~17" the shroud side to side is 27" it covers my rad openings
Old 04-16-2011, 09:50 AM
I replaced my '68 shroud with a repop...I remember it not being up to snuff...didn't look like the same finish as the original, but not that big of a deal. I thiink I did have to drill the holes. It does fit OK though.
Old 04-16-2011, 01:09 PM
Andre's Avatar
Andre Andre is offline
I had a repo '68 shroud in fiberglass, and also have an orignal '68 shroud in plastic. The shape and size seemed generally the same. I will sell the '68 shroud if you need it. email me at [email protected]
Old 04-16-2011, 01:30 PM
Yeah, I still have my original too...just had a cut in it. Looks like a previous owner wanted to be able to remove it without removing the fan. Very repairable but I still used the repop because it's not too bad and looks fine installed..Just a slightly different finish and I do recall drilling the holes now.
Old 04-16-2011, 04:12 PM
68gtoMN's Avatar
68gtoMN 68gtoMN is offline
FYI - all 68 shrouds, big car or small, were the same
'68 GTO 4-spd Hardtop (11)
'68 GTO Convertible AT (1)
'70 LeMans Sport
Land of Lakes Muscle Car Classic
Facebook Event
Facebook Wall (Kurt Smith,Minneapolis)
Old 04-17-2011, 09:49 AM
They are def not the same I finally got mine corrected and huge difference
