Old 04-22-2011, 07:28 PM
DrBoeing DrBoeing is offline
Default 69 GTO trunk pan
Has anyone here used the Dynacorn full trunk pan on their 69? If so how was the fit, especially around the tail light panel.
I ordered one from Goodmark but they say it is a crappy fit and would not sell it to me.
Does anyone have any other recommendation aside from Goodmark or Dynacorn.
Old 04-22-2011, 08:33 PM
andyg's Avatar
andyg andyg is offline
Send a message via AIM to andyg
I used one from the parts place (not sure of manufacturer) and it seemed to fit very well. Now, I'm no pro rebuilder and was learning to weld at the time, but it looks fine from the trunk.
1969 GTO. Full rotisserie restoration "completed" in 2014. 5.3L "LM7", TKO600, 3.55's out back. Big cam coming soon.
Old 04-22-2011, 08:50 PM
Thanks Andy. How did it fit around the tail light panel, especially the section where it rises up in the middle between the tail light holes. Did it fit right in or did you have to cut and modify
Old 04-22-2011, 10:26 PM
goatnut's Avatar
goatnut goatnut is offline
I installed a Dyna Corn 1 piece in my 69. Fit very well and I too am not a body man. How ever it will not go to the tail light panel as these were made for all A body cars and that part of the panel I believe is patterned for a Chevelle. It needs to be spliced in before the tail light panel as the hump for the fuel filler tube is differant.
ID:	242183   Click image for larger version
69 GTO Judge
69 Firebird Trans Am clone
76 Trans Am 400 4spd.
06 GTO M6 18's red/red - 1 OF 188.
09.5 G8 GT Stryker blue met. premium with sport pkg.
Old 04-22-2011, 10:42 PM
Did you use the hump section from the old pan??? In my case it is too far rotted to salvage
Old 04-23-2011, 06:41 PM
GTO JOHN's Avatar
GTO JOHN GTO JOHN is offline
I may have a hump for you to graft in.
I used a Dynacorn full pan in my Judge and luckily the original rear tailpanel hump was still usable. Fit very well
John
Email [email protected]
My Website www.minnesota-muscle.com
Old 04-23-2011, 11:03 PM
I will let you know, I will likely take you up on that. Is it in good shape.
Old 04-23-2011, 11:34 PM
goatnut's Avatar
Yes. If yours in in bad shape you will need a donor panel to graft in.
69 GTO Judge
Old 04-24-2011, 02:49 AM
Chipper7's Avatar
Chipper7 Chipper7 is offline
I am in the process of installing the one piece floor and yes they are different where they meet to the rear body panel plus it is about an inch shorter. Mine too was pretty bad where it welds to the rear body panel so I will have to fab something up to get all the measurements right.
Old 04-24-2011, 08:17 PM
PaulatFast PaulatFast is offline
There are two different trunk pans used on 69 gto's from the factory. The trunk pan was changed somtime in early april as far as I can tell. The early pan has an oval shaped hump on the front "shelf". Late pans have the same hump as the 70. Neither trunk pan is reproduced. The reproduction pan available is for a 68 gto. It has the correct "hump" for the early cars. For the later cars, a 69 Chevelle trunk has the propper shape. Both of these pans will need the entire rear section re-used from an original trunk.
Paul
FAST Automotive -The Pontiac restoration shop, not the fuel injection guys! I had the name first.
My site... needs updated-
www.fastrestorations.com
68 GTO's (RA II, RA I, HO, convert, Pro Street, Racecar, etc.), 2 69 GTO Judges, 70 GTO racecar -10.77 @ 124mph, 68 Tempest survivor, 3 03 Aztecs!
Old 04-24-2011, 08:23 PM
For reference, Goatnut's trunk hais the early style hump on the front shelf.
Paul
Old 04-24-2011, 08:48 PM
It was suprizing to discover there are actually three different 69 shells from the factory. june cars used the 70 upper cowl as well.
Paul
Old 04-26-2011, 02:12 PM
The photo of Goatnuts is also what I have in my 69, just as i stated, mine is far too gone to be useable so I am not on the hunt for a section to graft in.
Old 04-26-2011, 06:17 PM
JLHarper's Avatar
JLHarper JLHarper is offline
Paul, is this the ledge under the package tray, as seen in picture below posted from GTONUTS post?
Where is the OVAL HUMP again please? Is it where the gray primer is sprayed over the black coating on the ledge, in the center?
That was a great post, bty good info to know.
Thanks......
Old 04-26-2011, 09:07 PM
goatnut's Avatar
Jeff The OVAL HUMP is directly under the package tray.
69 GTO Judge
