Old 04-29-2011, 01:35 PM
JohnFromVentura's Avatar
JohnFromVentura JohnFromVentura is offline
Default Spark Plug in #7?
Ok ... I've changed a few spark plugs in my day but I can't get the ___ plug started in #7 on my 63/68 engine 400. It's under the steering shaft and it's a two finger job at the best. I have ground reliefs on the 13/16 th's short sockets that have and can't get the socket over a finger tight plug or get the plug started when it's in the socket! I have always worked on SBC's and Olds engines so this is my 1st go at a Pontiac. Is there something about Pontiac tool/head (#15) clearance? John
Old 04-29-2011, 01:40 PM
mechanickeith's Avatar
mechanickeith mechanickeith is offline
Is the exhaust gasket protuding any? had one that was a bit fat & socket hit it.
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 04-29-2011, 03:15 PM
one70gt37's Avatar
one70gt37 one70gt37 is offline
An old trick from an old mech. friend that has worked for me,, slip a short lenght of gas line or a small rubber hose over the end of the spark plug to help it get started, works for me on those tight plug holes. Hope this helps.
In Paldiumn silver
'70 Tempest GT-37
'68 428 cu.in.
M-21 4 spd.
3.73 12 bolt
Old 05-02-2011, 02:23 PM
fasteddy's Avatar
fasteddy fasteddy is offline
I had the same problem with my Lemans. I pried up on the steering shaft with a crow bar--just enough to slip the socket over the plug-not enough to bend the shaft. Then insert an extension in the socket and tighten. Pry up on the shaft to remove the socket. Hope this helps.
fasteddy
