Old 05-09-2011, 10:36 AM
Verl Verl is offline
Default convertible top issue
I am unable to get the top to go back up. Thinking I may need a new switch, since the last time I had it down, there was a hesitation before it came up (after wiggling the switch). Any suggestions?
Old 05-09-2011, 11:15 AM
Fred's red sled's Avatar
Fred's red sled Fred's red sled is offline
Could have blown the fuse. Esp if the top is stiff, rusty, dirty hinges etc. could be pump motor , air in lines, hydrolics and grounds.
Do you hear the motor try to work at all?
"Come on baby... Sit back, relax and enjoy the ride!"
Old 05-09-2011, 12:09 PM
arbys's Avatar
arbys arbys is offline
They draw a lot of cuurent especially if everything isn't up to snuff. There is an automatic circuit breaker in the system and when overheated will trip. You have to wait about 1-5 minutes for it to reset
Old 05-09-2011, 07:27 PM
Thanks guys, I appreciate it much. We (a friend who is not electrically challenged, and mechanical) did some testing, unhooked the wire to the top motor, and found no electrical current going to the motor, so we "jumped" the motor and at least got the top to go up. The motor would work in the down, but nothing in the up. It is all clean and top is not stiff.
I will try a new switch and report back once it's in. Thanks again for the insight.
Verl
Old 05-26-2011, 07:44 AM
The new switch from PY is what was needed. It was fairly easy to install also (would have been easier if I had tiny fingers).
