Old 04-05-2011, 06:12 PM
Father&Son73T/A Father&Son73T/A is offline
Thumbs up
Originally Posted by blue71ta View Post
your car is looking great; keep the pics coming!
Think it will be ready for the Indian Uprising show? Would love to see it in person.
x2!
1973 T/A Buccaneer Red L-75 A3,83k mi. #'s match
1979 T/A Atlantis Blue W-72 WS6 23k mi.survivor#'s match
1999 T/A Navy Blue 60k mi....babied
1968 442-gone but not forgotten
"Oh,you can think about it,.....but don't do it!"
Sheriff Bufford T.Justice
  #102
Old 04-05-2011, 06:59 PM
Held for Ransom's Avatar
Originally Posted by johnta1
The 73 wheels have the gray on the outer rim not silver, I believe.
Here are before pictures of mine...
ID:	240283   Click image for larger version
  #103
Old 04-05-2011, 07:19 PM
Norwood's Avatar
Norwood Norwood is offline
So is it gray?
  #104
Old 04-05-2011, 07:36 PM
Shadowing is making it look gray (grey), but it's silver, with overspray on inner rim.
  #105
Old 04-06-2011, 01:07 AM
I'll have to see if I can find the info on them.
My wheels were gray.
(but is a later build in 73)
  #106
Old 04-06-2011, 07:56 AM
x-bird2 x-bird2 is offline
my wheels were ....turbos ..... lol
  #107
Old 04-06-2011, 12:08 PM
Hotrodizz Hotrodizz is offline
I live in St Charles, so Ill be there.
  #108
Old 04-06-2011, 02:49 PM
3tas4me's Avatar
3tas4me 3tas4me is offline
Originally Posted by Hotrodizz View Post
What is the recommended procedure/sequence for installing the dash pad?
I removed it with the harness still in the car, but I'm unsure if the harness should be secured to the dash with the plastic retainers first, then the entire assembly bolted up and then mount the fuse box, etc, OR, does the harness go in before the pad?
Install the harness in the dash before installing the dash in the car.
1970 Trans Am
1971 Trans Am
1974 Trans Am
1978 Y88 Trans Am W72/auto
1979 10th Anniversary Trans Am
1984 Trans Am
1996 Trans Am WS6
1999 30th Anniversary Trans Am
2001 10th anniversary Firehawk #104
  #109
Old 04-17-2011, 10:44 AM
My original spare is silver, same as the other 4.
  #110
Old 04-17-2011, 11:21 AM
Between being busy at work, and family stuff, I have to squeeze time in on the TA when I can, so I'm only able to give it an hour here and there, but here is a little more progress:
Most of rear end components are installed and cleaned
I bought the "expensive" carpet underlay kit, and I just couldnt stand it, so I bought some bulk jute padding with silver backing, and cut it to the contours of the floor. Ive used the more expensive Dynamat type of insulation on other cars, but I didnt want to adhere anything to the perfect floors of this car. I also laid the new carpet that had been boxed for 9 months, so it can start taking the right shape. I then installed the rear lower plastics, and upper rear seat.
The original headliner was falling off the board, so my local interior shop removed all the foam, installed new, then re-glued the original material back on. He couldnt promise it will last, but for $50, I figured it was worth a shot and so far, so good.
The firewall heater box, harnesses and vacuum lines are also in place.
The engine side AC case is installed, as is the wiper motor, transmissions, and brake booster. I removed the plastic that the body shop had wrapped the front subframe in, but I havent blown all the dust off of it yet.
I hope to get a few more hours on it today
  #111
Old 05-10-2011, 09:22 AM
Been very busy with work lately, so I havent been able to dedicate much time to the car and especially updates, but here we go.
  #112
Old 05-10-2011, 09:54 AM
Norwood's Avatar
Very Nice Tom, it coming along GREAT.
  #113
Old 05-10-2011, 11:08 AM
CaptCrunch CaptCrunch is offline
Nice work!
  #114
Old 05-10-2011, 08:28 PM
Great progress. Going to be nice!
  #115
Old 05-10-2011, 10:15 PM
cnc's Avatar
cnc cnc is offline
where can u buy BULK jute padding ??
Car looks Fabulous keep it comin
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
  #116
Old 05-10-2011, 10:23 PM
Very, very nice.
  #117
Old 05-11-2011, 07:12 PM
1973T/A's Avatar
1973T/A 1973T/A is offline
Ive bought mine at fbodywarehouse before
  #118
Old 05-11-2011, 09:55 PM
I didnt buy it here, but this is what I used: http://www.summitracing.com/parts/THE-14120/
  #119
Old 05-11-2011, 10:05 PM
cnc's Avatar
cnc cnc is offline
thanks for the help....Chris
  #120
Old 05-19-2011, 01:44 PM
Got the bumper back and installed. I ended up using Badger Plating in the Milwaukee area. Turned it around in 3 weeks at a fair price. Looks flawless.
The Trim Parts carpet isnt fitting well, especially the rear piece. I ordered another rear only, and the fit is exactly the same. I cant live with it, so I ordered an ACC carpet. The dash pad I had dyed is showing an old repair, so the hunt begins for another. ALso still waiting on the engine builder.
While I am not finding much time to dedicate to the car right now, I feel like I cant progress much anyway. It makes no sense to put the seats in, before the dash, no sense to put doors on it while there is still interior work to do. I dont want to assemble the front sheetmetal until the car is running, etc, etc.
I plan on bleeding the brakes and putting the wheels on it, modifying aftermarket rear sway bar bushings and installing them. At that point, the suspension, brakes and steering are done. Sorry, done rambling..
