Old 05-19-2011, 03:35 PM
Brewster's Avatar
Brewster Brewster is offline
Looks great and hope to see it at the Up Rising! Did you offset that trunk seal like the factory?
  #122
Old 05-19-2011, 03:41 PM
Hotrodizz Hotrodizz is offline
Elaborate..
  #123
Old 05-19-2011, 06:51 PM
Brewster's Avatar
The factory offset the trunk seal onto the drivers side but most people place them in the center upon replacement.
Either way its one of those things that the average joe wouldn't notice. I for one just aint the average joe due to this disease I have.
  #124
Old 05-19-2011, 09:10 PM
Norwood's Avatar
Norwood Norwood is offline
Your about as far away from AVERAGE as it gets
  #125
Old 05-19-2011, 10:27 PM
weranc55's Avatar
weranc55 weranc55 is offline
Originally Posted by Hotrodizz View Post
Elaborate..
Looks nice. I need to get a bumper done fast. May give them a call. I'll point one thing out before someone else does. One of your rear spoiler ends is correct and the other one isnt. Good luck with your project.
  #126
Old 05-20-2011, 05:06 PM
dlcable's Avatar
dlcable dlcable is offline
Brewster, I'm just about to install my trunk seal, could you post a picture of the driver’s side off-set you’re talking about??
Thanks!
  #127
Old 05-21-2011, 04:54 PM
Which is incorrect, and who wants to sell me the right one?
Will post some pictures Monday, but I dont love the way the common aftermarket gray welting fits, so I purchased some black, more flexible rubber welting off of ebay. My initial impression is that I love the way it fits, but it seems a little more narrow than the original stuff. Going to mull it over, and will post pics of all three side by side Monday.
  #128
Old 05-21-2011, 05:54 PM
weranc55's Avatar
Im not sure for a 73 but the I think the short one is correct at least I know it is for 70.
  #129
Old 05-21-2011, 06:20 PM
Norwood's Avatar
short one for 73
  #130
Old 05-21-2011, 06:24 PM
ok, who can sell me a RH spoiler?
  #131
Old 05-22-2011, 07:38 PM
cdoggy81's Avatar
cdoggy81 cdoggy81 is offline
You can just cut your long one shorter. It is a very easy job to do as most of us here (70-73 guys) have done it. IIRC it's just a straight cut with a little smoothing in the corners
ID:	245108   Click image for larger version
73 TA 4 spd #'s match red/white - "STOLEN" AT TERRY SPEAR's SHOP IN Columbia TN ~mid 2014
Last offical pic of the car can been seen here:
http://clubs.hemmings.com/pontiactn/...%20-%20rev.pdf
People have seen it posted FS on Craigs List back in late 2013 early 2014....
IF YOU HAVE ANY INFO ABOUT IT PLEASE CONTACT ME!!!
  #132
Old 05-22-2011, 08:03 PM
Norwood's Avatar
I never did it, I only use original parts. But I may have seen it done before.
  #133
Old 05-22-2011, 08:18 PM
Got it.
It looks like my wheel flares were painted in a sand box, so Ill just have my other body shop friend mod the spoiler when he fixes the flares.
  #134
Old 05-22-2011, 10:27 PM
Brewster's Avatar
My original trunk seal seam is four inches to the right from the left driver side brake light. Will try and post some pictures for review soon and confirm.
  #135
Old 05-23-2011, 01:17 PM
Original, Gray Latex welting, Black rubber welting (which includes double sided tape)
The black welting is about the same width as the original, it is slightly different appearing. It is shown with the gray (painted) aftermarket welting.
The black welting appears to be made of rubber and not of latex so it is very soft and follows the contours of the flare very nicely
  #136
Old 06-03-2011, 09:30 AM
Current state of affairs....Dash is in and complete, Column is in place awaiting the repainted collar bracket, then console, glove box, front seats then steering wheel. at that point, I believe the interior is done.
Ill probably install the glass and doors next since I do not have the engine back yet, and cannot progress on the front end sheet metal.
The 3rd pic shows 3 connectors which I believe are for options my car doesnt have. Does this sound correct?
ID:	246015   Click image for larger version
ID:	246016   Click image for larger version
  #137
Old 06-03-2011, 10:40 AM
murphc4 murphc4 is offline
The connector in the middle is for Power Door locks. I can't recall what the other 2 are, I can check my wiring diagram tonight if someone else doesn't reply before then.
  #138
Old 06-03-2011, 12:58 PM
blue71ta's Avatar
blue71ta blue71ta is online now
Tom,
the car is coming along nicely. Hope to see it at the Uprising when it's done.
-James
  #139
Old 06-04-2011, 01:37 AM
charles bledsoe's Avatar
charles bledsoe charles bledsoe is offline
Your 73 looks fantastic, did you put a build sheet behind the back seat?
1966 GTO Vert automatic.
1969 CR Judge Ram Air III 4sp Pattern Car.
1969 GTO standard 350HP TH-400.
2006 GTO Phantom Black 6spd.
1972 Formula 455HO Ram Air.
1976 LE Trans Am 50th Anniversary Edition with T top.
1976 Formula 350.
1977 Grand Prix Model J 350.
1978 Trans am 400 Pontiac.
1979 Trans am 403 Olds.
1968 Olds 442.
1971 TR6.
  #140
Old 07-05-2011, 06:17 PM
Finished up most if the interior for now. I really intend to restore the original wheel at some point, but for now, the repro is installed out of the box. I was able to locate and dye a nice original 73 dash pad, it turned out very nice. The console is the original. I have to admit the dark red which I was skeptical about has really grown on me.
Hopefully the motor will show up so I can install it, then assemble the front end of the car.
ID:	248673   Click image for larger version
ID:	248674   Click image for larger version
ID:	248675   Click image for larger version
ID:	248676   Click image for larger version
1971 Trans Am 455LSX/T56 Clone
1973 Trans Am LS3/T56 in process
1977 Can Am....Sold
1973 Trans Am 455/Auto, White, # matching-Sold
1959 Impala TT LSX
1987 GNX #357
1969 Boss302 Clone w/Supercharged Coyote 5.0-Sold
2010 ZR1
2009 CTSV
www.speedinc.com
