I have never had a fan shroud on my 66. I'd like to buy one from PY but I'm not sure if it will fit properly - I have a flexalite 18" fan and ebay alum radiator. The center of the fan sits 9 inches from the top and 11 inches from the bottom of the radiator. The fan blade stops right at the top of my radiator.
Will it work or should I fab my own?
![]() 461ci, Edelbrock 72cc heads, KB 15cc dished pistons, comp xe274, PRW 1.5 roller rockers, Performer RPM intake, Holley 80508 750cfm, RARE oversized manifolds, Pypes X-pipe Exhaust |
Buy thier shroud and when you recieve it measure the diameter of the hole. then choose a correct fan that is about .5 inches smaller in diameter. choos a hydrostatic fan clutch that puts the fan centered in the middle of the opening. not too far inside the opening and not to far outside the opening. Then select a fan from GM's many choices and install it using grade 8 hardware.
I have found that the best fans come frommmid 70's chevy trucks. close in DIA and HD and many fan blades. That flex-O-Lite fan only flexed open your wallet and lightened it |
