Old 06-01-2011, 12:10 AM
65GPnoob 65GPnoob is offline
Default 65 GP motor turns so far then stops
I'm new to the PY forums. I bought this 65 GP with a 389. Its been sitting since 1974. I had the motor turning over trying to get it to start. Then late yesturday it stopped turning. Went out and messed around with it and got it turn over,but it turns so far one way then stops. Turns back and stops. So any ideas? My guess its something to do with the valve train. Thanks
Old 06-01-2011, 12:43 AM
sleepy's Avatar
sleepy sleepy is offline
Is there a clunk when it stops turning? How far can you turn it before it stops? 1/4,1/2,full turn, almost two?
Why is he not suspended?
Old 06-01-2011, 01:13 AM
mechanickeith's Avatar
mechanickeith mechanickeith is offline
Sitting a long time, I'm thinking a valve stuck open. Piston hitting it.
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 06-01-2011, 01:15 AM
sleepy's Avatar
Or a lifter stuck. Or a valve stuck shut.
Old 06-01-2011, 01:51 AM
chupiw1 chupiw1 is offline
I had this happen once, took the heads off and one cylinder had rust in it all the other cylinders were fine. No matter what i would pull the heads as have a look, cant hurt.
Old 06-01-2011, 02:31 AM
Pontirag Pontirag is offline
or rust build up on a cylinder wall, but forcing it to crank over might breake rings
Old 06-01-2011, 07:29 AM
It was turning over all day long. Now it turns over more then half. There is alot of sludge under the valve covers. I know I need to tear the motor apart,but right now I want to get it running enough to get it off the street. The car only has 70000 miles but PO didnt take good care of it. On another thought weres a good place to get a ignition lock cylinder with keys? Thanks for all the help.
Old 06-01-2011, 07:39 PM
Motor turns over only 180 degree's. I dont think its the valves. Going to pull the fuel pump.
Old 06-01-2011, 09:04 PM
66bonne's Avatar
66bonne 66bonne is offline
Regarding ignition : Check with our host Performance Years.
Jim
Old 06-01-2011, 10:14 PM
I pulled the intake and the fuel pump. I'll check the lifters tomorrow. All the rocker arms seem to be the same. Still could be a valve I guess. Motor stops when #5 and #8 piston are at the top. Noticed loose debris in #5 spark plug hole. Looked in the fuel pump hole at the timing chain looked ok. Most likely going to pull the heads. Like Pontirag and chubiw1 suggested.
Old 06-05-2011, 10:37 AM
Found the problem. Carbon crud in the #5 cylinder. I dont think this motor has been rebuilt. The cylinders look good. What can I put in the gas since it most likely it doesnt have hardened valve seats?
Old 06-05-2011, 11:12 AM
Years ago bought a SBC hauled it home in the back of a truck-a little sleet falling. Next day turned it over same deal stopped one way , then the other way.Thought got a bum motor.Pulled the head and some freezing rain had gotten in the cylinder and frozen hard!
