Old 06-27-2011, 08:04 PM
1312obx 1312obx is offline
Originally Posted by riceslayer View Post
I thought you could get to them through the trunk...
I wish it was that easy. The tail light assembly is in the bumper. There are 4 screws above each taillight assembly, but removing them does not loosen the assembly. The panel inside the trunk, is solid and does not provide any access. There is a rubber plug that accesses a 3/8 or 7/16 in. bolt, but it is not attached to the tail light assembly.
There is no access underneath. After removing the metal pan, you can see the tail light wiring and sockets. Unfortunately the sockets do not plug in from the bottom. There is no room to reach the rear of the sockets, they are above a piece of angled metal.
I know there must be a simple solution. I talked to an owner of a 1968 GP and his tail lights are plugged in from the bottom.
