Old 06-22-2011, 11:17 PM
1312obx 1312obx is offline
Default Need help on 70 Bonneville
How do you change outer brake light bulb? The repair manual gives great detail on changing the tail light lens, but there must be a better way to simply change the bulb.
Old 06-26-2011, 02:00 PM
riceslayer's Avatar
riceslayer riceslayer is offline
I thought you could get to them through the trunk...
riceslayer's Avatar
Where do ya live?
Old 06-26-2011, 02:01 PM
riceslayer's Avatar
I know how to put headers on that baby, I got em on my 69.
Old 06-27-2011, 08:04 PM
I wish it was that easy. The tail light assembly is in the bumper. There are 4 screws above each taillight assembly, but removing them does not loosen the assembly. The panel inside the trunk, is solid and does not provide any access. There is a rubber plug that accesses a 3/8 or 7/16 in. bolt, but it is not attached to the tail light assembly.
There is no access underneath. After removing the metal pan, you can see the tail light wiring and sockets. Unfortunately the sockets do not plug in from the bottom. There is no room to reach the rear of the sockets, they are above a piece of angled metal.
I know there must be a simple solution. I talked to an owner of a 1968 GP and his tail lights are plugged in from the bottom.
Old 07-04-2011, 01:01 PM
dedsleds's Avatar
dedsleds dedsleds is offline
that rubber plug and nut is the bumper bolt. there should be 4 5/16 head bolts underneath and once removed you could side out or down the bulb assembly. isn't there screws on the lenses? i took one apart and kinda forgot.....
1959 catalina 4dr a/c car
1970 gp strip car ...
1972 gp j 455/4
1971 bonneville hearse 455/4
1972 grand safari wagon 6 pass 455/4
1995 Firebird Formula 5.7 convertible
2002 gp 40th anniv. SC V6
2003 gmc sierra 2500hd 8.1 liter
***LIKE MY FACEBOOK PAGE https://www.facebook.com/GratefulParts***
http://stores.shop.ebay.com/GRATEFUL...__W0QQ_armrsZ1
