Old 06-18-2011, 07:42 AM
Gr8 1 Gr8 1 is offline
Looking good Ron! I like what you did with the gauges. If you need help with anything, you have my number. Doug
  #122
Old 07-11-2011, 12:01 AM
ron cozzo's Avatar
ron cozzo ron cozzo is offline
Progress update, made many modifications to the dash harness so that the '65 rally gauges would work:
'04 GTO Yellow Jacket, A4, Kooks, CAI, etc.
'02 Firebird, V6, auto
'68 GTO Convertible, HO, 4spd, driver
'66 LeMans Hardtop, 400, FI, A/C, 4L80E.
'65 GTO Hardtop, restoration ongoing
'64 GTO Hardtop, "389", Tri-power, 5 speed, A/C, Yorktown Blue.
http://www.gtoaco.com
  #123
Old 07-11-2011, 12:03 AM
ron cozzo's Avatar
After all the cutting and splicing, the dash harness got re-wrapped with grey tape (correct for an A/C car), thanks to Prairierust for the tape:
  #124
Old 07-11-2011, 12:13 AM
ron cozzo's Avatar
Then the fun part, stand on your head trying to get all of the dash/harnesses/ducts etc. to be happy with each other under the dash. I had the radio in and out three times. The glove box in and out three times, etc. Had to build my own rear defroster harness for the switch, requires a resistance wire to add the low speed. Not sure why, but the vent balls have been on backorder for a long time. A/C cars are a bitch getting everything stuffed in there:
ID:	249290   Click image for larger version
  #125
Old 07-11-2011, 12:17 AM
ron cozzo's Avatar
Digging though a box I had forgotten was there I found my original accessory grommet which we had a separate thread about. Two speed wiper harness on top, tach in the middle, A/C harness will go in the bottom:
  #126
Old 07-11-2011, 12:26 AM
ron cozzo's Avatar
Also finished up the engine accessories, belts, fan, etc. Sorry, I didn't polish the blades. They were pretty rough, lots of corrosion/pits, so I bead blasted it. I did have lots of fun masking the fan for painting the black part, and then painting each rivet by hand. Also got the clutch linkage finished, I ended up using the two spring set-up from '66/'67. Need to get the steering column, engine harness, starter, A/C harness in, then I can put the front clip on.
ID:	249293   Click image for larger version
ID:	249294   Click image for larger version
  #127
Old 07-26-2011, 08:40 PM
ron cozzo's Avatar
Small progress update: I got the starter in with the modified length positive cable from M&H to route the '67 HO way. The engine and A/C harnesses were rewrapped in grey tape and routed. Just need to get the column in before I put the front clip on. Between our club's show this coming weekend, Norwalk, and work, I'll be hard pressed to have the fenders on in August.
Name:	2011-07-26 002 (Large).jpg
ID:	251448   Click image for larger version
Name:	2011-07-26 004 (Large).jpg
ID:	251449   Click image for larger version
Name:	2011-07-26 005 (Large).jpg
  #128
Old 07-26-2011, 09:13 PM
Dick Boneske's Avatar
Looks terrific, Ron. You'r about as far on the firewall-forward as I am. Frustrating how long everything takes!!
BONESTOCK GOATS
'99 Bonneville SE Sedan
  #129
Old 09-19-2011, 06:58 PM
cspecken cspecken is offline
Default Paint
Hi Ron, my paint color is the same as yours, can you post up the paint mix information for both the exterior and interior if you have it available? Or was it a custom mix?
Thanks, Chris
  #130
Old 09-19-2011, 07:57 PM
61 vent 61 vent is offline
Your car looks great!!! Awesome attention to the small details.
  #131
Old 09-19-2011, 08:05 PM
GT182's Avatar
GT182 GT182 is offline
Looks great Ron. BTW, leave the a/c vent balls out. Then you can slip a can of your favorite 'brew' in either one to keep it cold.
We need more photos too. Yer just teasing us with the ones posted so far.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
  #132
Old 09-19-2011, 10:45 PM
ron cozzo's Avatar
Thanks, Chris
Chris, here's the information for the Yorktown Blue, straight off the can.
ID:	257199   Click image for larger version
  #133
Old 09-19-2011, 10:55 PM
ron cozzo's Avatar
The interior blue was a custom mix, my paint shop wasn't able to use the codes I provided to find it.
They did a great job matching the color. I had only one good sample of the original blue, under the ash tray trim plate. Not big enough to scan, but enough to manually match to. Unfortunately, for some reason, they mixed it in a vinyl paint system. My painter sprayed it before I realised the mistake. But, I liked it, so left it. The lower dash and door areas are not as glossy as they should be, I'd guess 30-40% gloss, versus the 60% or so it should be. The 0% gloss on top of the dash came out really well, and has a nice silky look. I wouldn't recommend this paint system for a stock restoration. That said, here's the codes.
ID:	257201   Click image for larger version
  #134
Old 09-19-2011, 10:59 PM
ron cozzo's Avatar
Thanks GT182. Funny thing about those missing vent balls, nobody has them. I've got them on backorder at two different places for months now and nothing. I may have to find some originals and have them replated.
  #135
Old 09-20-2011, 12:02 AM
Did your paint shop match the Yorktown Blue to something from the car or was that just from the paint code? I have a 62 Wagon that needs to be the same color, My buddy that owns a body shop told me to wait until I remove the front fenders and get to the untouched part of the cowl so we can match it. He does not think that the code would be a perfect match. If yours was matched to something I will give him this information and see if he will mix some up for me. Andy in Tucson
  #136
Old 09-20-2011, 12:10 AM
ron cozzo's Avatar
The Yorktown Blue formula I showed was made strictly from the Dupont codes, we did not match it to original paint.
  #137
Old 09-20-2011, 12:19 AM
Ok thanks.
  #138
Old 09-20-2011, 05:44 AM
Subscribing to this thread. Don't know how I missed it all this time.
I have to say, the level of craftsmanship displayed on some of the cars on this forum..and in particular, this one... is enough to make me go out and throw ROCKS at my projects. This car is stunning.
Old 09-20-2011, 11:04 AM
Thanks Ron, I appreciate the information. It will make it a little easier now when it is time to get the paint. I am not building a concourse project so if the color exterior / interior is off some I am not too worried about it. I just want something that is as close as possible.
Your car looks great, I bet it is hard towards the end of your project, when in all reality all you want to do is get in it and drive the snot out of it!!!
Chris
  #140
Old 09-20-2011, 12:20 PM
6 Grrrs's Avatar
6 Grrrs 6 Grrrs is offline
x2. Beautiful car Ron.
Tod Hoffmann
1966 GTO Montero Red Hardtop - Holley EFI'd 462, KRE DPorts/Muncie 4spd
1990 Chevy 454SS pickup - Accel DFI/T56 6spd - Hot Rod Power Tour Long Hauler
1996 Chevy K2500 ECSB 'Poopy'
2002 Honda VTX1800C
2016 Cadillac CTS Premium
My project thread: http://forums.maxperformanceinc.com/...d.php?t=516826
