Old 06-17-2011, 05:50 PM
421gto's Avatar
421gto 421gto is offline
Default where to buy 421 pistons from
we are having a 65 421 rebuilt, but wheres the best place to get a new set pistons from ? Its going to be stock so we dont need anything special, just stock.
I know egge machine have them listed, someone else said wiseco.com - any others ?
cheers from a very wet UK,
si
www.pontiacuk.com
Old 06-17-2011, 06:24 PM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
Here's some stock replacement that are the hypereutectic type and claimed as stronger than factory cast although forged would be preferred to help resist damage from potential detonation since stock heads yield around 10:1 compression.
http://cgi.ebay.com/ebaymotors/421-P...-/200309977778
They say all bore sizes are available. $398
63 Catalina coupe 467 cid budget drag car low 11's 1/4 , 7.0's 1/8th pump gas n/a
66 Star Chief Executive 59k mile 389
67 IH Scout project 2WD "Indian Scout"
69 Le Mans 2 dr HT 350 91k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 108k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2008 Saab 9-3 2.0T convertible
Old 06-19-2011, 06:35 PM
Ragtop Man's Avatar
Ragtop Man Ragtop Man is offline
2X -- but the incremental lifespan of a detonating engine with forged pistons (v HE cast) is not a whole lot longer.
Stock replacement pistons put you in the 10-2-10.5 range depending on the cyl heads, you need to build for the fuel you have in the area. IIRC, euro pump gas premium is something like 96 octane, so a cast rebuilder piston should be okay.
Only problem: with the cost of gas, a fill up is more than the pistons!
BOB
Old 06-20-2011, 02:09 AM
lust4speed's Avatar
Stock 421 bore is 4.09375 and stock 428 bore is 4.12 so you could bore out to the 428 piston size. They should be more readily available, and it only requires about a .026" cut - or not even a standard .030" 421 overbore size.
Mick Batson
Old 06-20-2011, 04:26 PM
421gto's Avatar
thanks guys, think we may have it sorted now, was talking to the engine builder yesterday and it looks like we are going the 428 route.
Bob, filling up with gas does seem to double the value of most cars...........
cheers
si
www.pontiacuk.com
Old 07-17-2011, 04:20 PM
coreybrenner coreybrenner is offline
On another note, I'm thinking of stroking the 389 in the parts car to a 421, but would like to use later model heads because of their superior combustion chambers. Is there a piston which will work with the later-model valve angles (but not be the 8-eyebrow weirdo-cut ones)?
I'm thinking of running propane in the finished product, so high compression isn't a big downer.
Old 07-17-2011, 04:51 PM
Standard bore 428 pistons will be what you want. The valve reliefs will be in the right place for the later model 14-degree valve angle heads, the 389/421 originally used 20-degree heads.
I have been shopping around for affordable 421 pistons myself, the one that catches my eye is the $465 Probe SRS 428 Flat Top piston set which can be had in +.005" oversize (4.125"), you can see it listed here on the PPR site:http://pacificperformanceracing.com/...-bearings.html
This +.005" 428 size will require boring your 389 block +.0625" over the stock 4.0625 bore size. In comparison just about any off the shelf 428 piston you'll find is +.030 (4.150") and is going to require boring your 389 block +.0875 over.
Of course you can order Ross pistons in any bore size and top configuration you like (dome, flat top, dished) for around $700 a set.
Old 07-17-2011, 06:00 PM
Awesome. I didn't catch whether the Probes were forged or not, though. I had thought about 428 standard-bore forgings, but was trying to get away with the minimum necessary overbore. I'd rather not hog out the cylinders, if I don't need to, but if I need to, then I guess that's how it'll be. 'Course, going with later heads begs the question, "why not just go with a 400 block"? And since I've got one, I may just do that. Hmm.
Old 07-17-2011, 06:09 PM
The Probe SRS 428 pistons are forged with a flat top with 2 valve reliefs (total volume of 5.5ccs) , sorry I didn't mention that.
To avoid boring your 389 block excessively you can get Ross forged pistons in pretty much any bore size as long as there is a piston ring set available in the size you want. To do it a bit more affordably you'll have to settle for 428 pistons in either std or +.005", unfortunately std bore 428 pistons are not readily available off the shelf these days.
Old 07-18-2011, 03:12 PM
I like the sound of the Probe .005" over 428 piston for a nice 4" forged crank 389-400 build. A super HD 59 389 block bored .0625" with a 4" forged stroker and Tomahawk rods.. MMM
