Old 08-10-2011, 10:38 PM
trot27 trot27 is offline
Default Tail lights non operational
When I purchased my '68 Lemans I knew the tail lights weren't working, but the brake lights and turn signals/ hazards work fine. I replaced the 20A fuse, and the tail lights worked fine......but then I took it out for a spin and obviously used the brakes/ turn signals. I learned that I burned thru my new 20A fuse again. I then trieda 25A fuse and almost immediately burned thru it as well. I THEN put in a 35A fuse temporarily just to see if the fuse held. It did, but I noticed it was getting HOT, so I took it out for fear of fire etc. WITH the 35A fuse in though, the tail lights did NOT work.
Even with the fuse out, my brake lights/ turn signals work fine. I checked the wiring in the trunk which leads to the tail lights and all the wires are in tact and not "worn" thru from years of items being thrown in the trunk, so there's no "short" present. I'm baffled at this point and would appreciate any pointers of where to turn next?!
Old 08-11-2011, 09:02 AM
2002Z4CSS's Avatar
There is a short somewhere on your brown wire to the tail lights. Try disconnecting the rear harness connector and see if the short is gone or not. That will help tell you which half of the car the short is in.
1971 Pontiac GT-37
Old 08-12-2011, 01:10 AM
where is the rear harness connector?
Old 08-13-2011, 08:25 PM
g68mike's Avatar
g68mike g68mike is offline
Should be in the area of the drivers side trunk hinge, inside the trunk
Old 08-19-2011, 06:42 PM
SWEETJUDGE's Avatar
SWEETJUDGE SWEETJUDGE is offline
did u check all your grounds???? i didnt read all above....
both housings should have a ground strap to each socket.... check there tooooooo
1969 Early 01D JUDGE #s MATCH RA III 4 Spd (Concours Restored)
1969 PRO STREET GTO 2500 lbs. ALL ALUMINUM 505
1969 RARE All Glass GTO (FOR SALE) YOU NEED THIS
AC Cobra Kit Car 521 670 HP/715 Trq
LOOKING FOR V PARTS !!!!!!!!!!!!
