Old 08-17-2011, 04:09 AM
Sharkbait40's Avatar
Sharkbait40 Sharkbait40 is offline
Default Whats Stronger then Aircraft stipper?
Hello - I have an aluminum cabinet that I got at the swap meet last week. It's a big GE Traffic control box. It had one layer of school bus yellow on it which I was able to remove with some A/C Stripper and a paint scraper. It has another layer of black paint or something that doesn't to bubble up like the yellow paint did. I know I could take it to someone to blast it but, my funds are limited for this project so I'm trying to do it on my own. Any ideas as to how to remove the old black paint as the stripper isn't working?
Thanks, Russ
Old 08-17-2011, 04:52 AM
68Catalina68 68Catalina68 is offline
DA sander with some 80 grit or put the aircraft stripper on and lay a piece of plastic over it so that it doesn't evaporate before it starts working. We use something called Chisel that comes in a spray can, that may work better. Good luck
http://www.amazon.com/CRL-LOCTITE-Ch.../dp/B000P1NT48
Old 08-17-2011, 05:45 AM
Cammer-6 Cammer-6 is online now
it may be powder coating which is tougher
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 08-20-2011, 08:45 AM
Try a razor scraper.
Old 08-25-2011, 10:27 PM
GT182's Avatar
GT182 GT182 is offline
Brake fluid will do the trick too.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 08-26-2011, 12:20 PM
dmorg1's Avatar
dmorg1 dmorg1 is offline
Russ,
If the black coating under the paint cannot be removed with paint stripper or the likes it is most likely an Anodic Coating and will need to be sanded off or there may be a reverse method used by industrial plating/coating companies but probably quite expensive.
Dave
68 GTO
68 GTO Convertible
68 LeMans
68 LeMans Convertible
68 Tempest Convertible
79 Firebird
