Old 08-28-2011, 07:48 AM
RedDirtRoad RedDirtRoad is offline
Jumped back on my car again.
Just set the body on the frame. Used new body mounts. I can now concentrate on installing all the A/C, new glass, vinyl top and dash.
ID:	254725   Click image for larger version
ID:	254726   Click image for larger version
ID:	254727   Click image for larger version
Old 08-28-2011, 10:34 AM
bigpop bigpop is offline
Progress, I love it!! I was wondering, while looking at the previous photos early on in the
restoration, the markings I see, in paint, not the paper tags, did you just copy what was visible after cleaning? Or, someone give you suggestions? I am a detail guy,too. Just curious as to the source. Great job so far!! Larry Banks
Mr. President, you can't say Dallas doesn't love you "
Old 08-28-2011, 10:39 AM
GT182's Avatar
GT182 GT182 is offline
RD, by any chance is that Martinique Bronze? Tho it sure looks great no mater what color is.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 08-28-2011, 10:58 AM
Larry, Its a little bit of both
I found original markings in the car after i carefully cleaned parts and got suggestions and tips by the best...Scott Tiemann
Old 08-28-2011, 11:00 AM
Its actually Silverglaze Met.
It doesnt look as brillant in the latest pics maybe its the lighting
Look at my earlier posts and you will see it fresh out of the paint booth and the color is much different looking
Old 08-28-2011, 03:09 PM
GT182's Avatar
Wow it's got to be the lighting, it sure fooled me. LOL That Silverglaze Metallic looks great. You don't see too many silver 67 GTOs around. Last time I saw a silver GTO it was a 66, and that was back in 1969 at the college I went to.
Gary
Old 08-29-2011, 02:46 PM
6d7gto 6d7gto is offline
Do you still need a WA Qjet tag? I gave away the bowl it came on but kept the tag. Not sure if that's what you meant by needing a WA tag. It's Rochester brand, dated D7. It lost its blue color though, so would need to be re-anodized.
Robert
[email protected]
Old 08-29-2011, 03:22 PM
SD421's Avatar
SD421 SD421 is offline
Originally Posted by RedDirtRoad View Post
Photos of the frame.
Hope to have the engine and transmission on the frame this week and the body to follow in the coming weeks
Should make a nice winter project
Grrrrt! Thread (pun intended)
I believe the rear swaybar was not an option on the earlier A-bodies. Maybe for Oldsmobile but not Pontiac. Also the lower rear control arms would not be boxed.
It does help with handling but its not correct.
Don
1966 GTO
1966 421-10.1-1 comp-Race Tec 23cc Pistons
KRE Tri-Power
KRE 65cc Aluminum Heads
XE274 cam by Comp Cams
DUR 230 Int 236 Exh @.050 - 110 LSA
LIFT .491" Int .491" Exh
Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers
1966 Muncie Wide Ratio 4-Speed
1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears
Old 08-29-2011, 03:38 PM
Don,
You are 100% correct
I have a few things I have done to the car thats not original but did so anyway just for better handling and driving.
The sway bar is from a later Pontiac. I also have a Trans am steering box and front sway bar too. I rather it handle best it can and lose judging points.
I welcome all criticism from others too..I like hearing feedback how my restoration can be better
Old 09-03-2011, 01:38 PM
ChuckG's Avatar
ChuckG ChuckG is offline
I believe that this is the power steering cap you were looking for:
http://cgi.ebay.com/ebaymotors/_W0QQ...T#ht_707wt_941
I bought one from this place last month and really like it.
Chuck
Old 09-03-2011, 01:52 PM
Thanks Chuck,
I already bought the correct P/S cap, the correct breather with the dimples too.
I now have the car on the frame, Factort A/C installed and working on the firewall and dash board and instruments.
Old 09-04-2011, 01:21 PM
ctgross ctgross is offline
I think I finally figured out the pic file from that 66 at the car show.....so here goes??
ID:	255480   Click image for larger version
ID:	255481   Click image for larger version
ID:	255482   Click image for larger version
CT Gross---66 GTO
"Its never too late to have a happy childhood"!
I told my dad I was going to stop raising hell, and he called me a quitter!
Old 09-04-2011, 01:36 PM
and a couple more(mine is the blue car) and the last pic is with him, he's a retired capt. with the Arkansas State Police.
ID:	255484   Click image for larger version
ID:	255486   Click image for larger version
ID:	255487   Click image for larger version
CT Gross---66 GTO
Old 10-31-2011, 08:26 AM
Default Making Progress
I installed the A/C heater box, dash board, instruments, wipers and brake booster and lines.
Did alot more work over the weekend and will post more photos tomorrow
ID:	261680   Click image for larger version
ID:	261681   Click image for larger version
Old 10-31-2011, 10:17 AM
SD421's Avatar
Looking GOOD!!
If I might make a suggestion. Put something over the top of the carb so nothing falls down inside.
Don
1966 GTO
KRE Tri-Power
Old 10-31-2011, 11:16 AM
68gtoMN's Avatar
68gtoMN 68gtoMN is offline
Beautiful job. I know how much work this can be and the expense is significant to "do it right"!
I have a comment regarding the installation of the limited slip tag. It is on correct bolt; however, the tag appears to be installed incorrectly - as are most. Tag should be installed at angle (about 45 degrees following contour of diff cover with tag extending up to the right), text on tag should face the front of the car, tag is bent back over the bolt to ensure that the tag could be read and that anyone changing the cover would need to see/move the tag in order to change fluid. This was done to greatly increase the likelihood that the proper additive was included in the refill.
I have two 67 factory original differentials, both with tags affixed as described above. Neither shows signs of having ever been taken off. Tags had only 1 imprint from the bolt in the aluminum, no scraping aside from the bolt as originally tightened.
Also, if my memory serves me correctly, the diff should be painted - not completely, but on the back/underside. I'll have to check my pictures at home to be certain, however.
'68 GTO 4-spd Hardtop (11)
'68 GTO Convertible AT (1)
'70 LeMans Sport
Land of Lakes Muscle Car Classic
Facebook Event
Facebook Wall (Kurt Smith,Minneapolis)
Old 10-31-2011, 11:38 AM
ERIC AULL ERIC AULL is offline
Beautiful car...GREAT color!!! Eric
  #38
Old 10-31-2011, 02:52 PM
GT182's Avatar
RDR, what is your package tray like if it's an original? Does it have a metal 'screen' on it, or is it plastic like the reproductions?
Gary
  #39
Old 10-31-2011, 07:39 PM
Eric,
Thanks for the compliment.
I also need to thank Andre. I bought a few original parts form him to keep the resto going.
He has very nice original parts that are faily priced too.
68gto,
You are correct on both issues. I recently found the same info concerning the posi tag on the rear diff and i will fix that.
The rear axles were assembled and unpainted on the assembly line but once the car was completed they reach under the car and sprayed everything satin black.
After all the work I have done to restore the car I just can paint it black overspray like the factory did. I guess I will just have an over restored car.
  #40
Old 10-31-2011, 07:40 PM
The only package tray material I ever had on my original GTO was black cardboard with a vinyl trim that was tucked behind the read seat.
