Old 11-10-2011, 01:18 PM
LemmyThe1972Wagon's Avatar
LemmyThe1972Wagon LemmyThe1972Wagon is offline
Default engine stand mounting bolt sizes?
i just need to know what grade and seize of bolts i need to use to attach a pontiac V8 to a 360 degree rotating engine stand. i've got to remove an engine tomorrow morning, and i have the lift, i have the stand, i just need to right size/length/grade bolts to actually attach the block to the stand so i can start disassembling it. surely there are engine builders here who can help me out here.
proud owner of a 71 Grand Prix and a 72 8-seater LeMans, currently in the body shop while I start the 467/4 speed build
Old 11-10-2011, 01:50 PM
Don 79 TA Don 79 TA is offline
3/8" 16 thread
length will depend on the stand too
if i am not mistaken typically 4-6" in length
i think mine on my last stand were 4" long
summit sold a various bolt kit for this and the size was in there
i think it was like $5 or so for the kit, maybe a little more
i was able to use some of the hardware for other things, so worked out for me
i think a visit to home depot/lowes would get you what you need
Old 11-10-2011, 02:03 PM
alright, so 3/8", #16 thread. i think i'll get a set of 4" and 5" just in case. it's only another buck or 2. great, thanks a lot.
Old 11-10-2011, 07:23 PM
4dblnkldude's Avatar
Yes 3/8 16 unless it is an early block, than the bolts would be 7/16.
Old 11-10-2011, 08:51 PM
Grade 5 or better yet grade 8. Do not use ungraded standard bolts.
Old 11-10-2011, 09:30 PM
Buy the 5" bolts and a bunch of 3/8" flat washers and you should be good to go.
Tom Vaught
Old 11-10-2011, 09:46 PM
GTOLou GTOLou is offline
I've never had to go longer than 3 1/2" long for most of the stands I have used. Be careful with the upper bellhousing mount holes that don't go all the way through. You don't want to bottom them all the way out and over tighten them. The lower mounts near starter pad/oil pan go all the way through - don't have to use but one washer.
Old 11-11-2011, 01:54 AM
Craig Hendrickson Craig Hendrickson is offline
Pontiac performance Author
That's all I use. No sense taking a chance with your expensive engine.
Craig Hendrickson, the "H" in H-O Racing Specialties.
http://www.OriginalHO.com
Old 11-11-2011, 09:53 AM
what year range are you talking for an early block? i'm attaching a '79 301 to the stand now, but my other engine is a '72 350.
Old 11-11-2011, 10:22 AM
Ollie's Avatar
Ollie Ollie is offline
Early block, 55 to early 60's. The 79 and 72 blocks are ok with 3/8-16
Its ok to giggle and snicker, Dont laugh and point
Old 11-11-2011, 11:49 AM
okay, great, thanks.
