Old 11-09-2011, 01:09 PM
Keith Seymore's Avatar
Originally Posted by Dr. Eric M. Schiffer View Post
Chuck Broomfield while he could get out about five Royal Bobcat kits installed in a day. He had a bottle of Maalox at his station in the service area back then. I understand he is still around.
I've mentioned before, but Dad would go down to Royal, load up with five or six tripower setups, "Bobcat" them at home and then take them back to Charlie to install on customer cars.
Same thing with transmissions (converting wide ratio trans to close ratio).
Naturally, if one of them turned out particularly nice - he would keep that one for himself....
'63 LeMans Convertible
'63 Grand Prix
  #362
Old 11-10-2011, 02:30 PM
Dr. Eric M. Schiffer's Avatar
Dr. Eric M. Schiffer Dr. Eric M. Schiffer is offline
Send a message via AIM to Dr. Eric M. Schiffer
Kapuskasing, Cahnada, eh.
I try to avoid going there as much as I can.
I was at the DPG for four years. Two of my daughters were born while we were out there. Best time of my life.
Keith,
I see the temperature is so low it's looks like the thermometer is broken. What does it say 70 below zero. Is that celcius or farenheit?
Say why isn't any one of the Volts plugged in? Not a long enough extension cord?
How old is your business card from the proving grounds? It still has area code (313).
Hope everything is going well with the move. Maybe we'll see you on Saturday. We could always ask Darwin Clark to pick you up as he comes down from Grand Blanc.
See you soon
Eric
1968 Firebird Ram Air, "Jim Wangers' Black Bird"
1968 GTO Convertible
2002 Corvette Z06
  #363
Old 11-12-2011, 10:04 AM
I'm not going to attach the entire packet. But here are a few more pictures.
Arlen sure has gained a few pounds over the years. Look back at the picture I took of Arlen by Jim Wanges' Judge when I had it at the Detroit Autorama in the late 1990's
I noticed in the photos on post #349 that the 389 valve covers are both turned with the 'pyramids' to the rear....Do that around here you'll get called out on it pretty quickly as having the passenger's side cover on backwards.
Never did hear what those 'pyramids' were for...
  #364
Old 11-12-2011, 11:54 AM
SD421's Avatar
SD421 SD421 is offline
While I was only introduced to Mr. Knafel I do have the 1966 Drag Strip Tin Indian promo kit that was sent to all the top drag strips around the country.
I'm only going to attach a part of the contract and narrowed the page so some things are cut off. That is because I'm sure there is going to be some 'Judge" guy that likes selling bogus "Ace Wilson" stuff on ebay, in Hemmings and other places. Who will try to duplicate this stuff to without authorization. Isn't that right, Robert!
Don,
Notice that the TIn Indian team was also a 1966 National Champion with those heavy Hurst wheels.
Hurst was a sponsor of the Tin Indian Team too.
The contract talks about racing in NHRA but I read in a certain book that they only raced in AHRA??
Any insight Dr. Schiffer?
Don
1966 GTO
1966 421-10.1-1 comp-Race Tec 23cc Pistons
KRE Tri-Power
KRE 65cc Aluminum Heads
XE274 cam by Comp Cams
DUR 230 Int 236 Exh @.050 - 110 LSA
LIFT .491" Int .491" Exh
Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers
1966 Muncie Wide Ratio 4-Speed
1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears
  #365
Old 11-12-2011, 03:11 PM
Default Valve covers
Greg,
Look closely at the on stand shot. The valve covers are not bolted on. In the installed shot you will see the valve covers are on correctly. Mountain forward on passenger side with drivers side mountain to the fire wall.
I don't know the reason for the mountain on only one side. But, I did ask the late Mac McKellar why the oil sheilds, under the 1967 valve covers and newer engines and over the rockers arm that, where replaced by valve covers with drippers on them and no oil shields? Was there an oiling problem?
Mac's answer was that this was the inventor in him. It was a cost savings only. Never a oiling problem on top.
Eric
2002 Corvette Z06
  #366
Old 11-12-2011, 03:24 PM
Default Tin Indian NHRA and N.A.S.C.A.R
Don
Don,
I don't know what book you read. But if you look at the quarter panels at the top edge of both cars it say's:
"1966 NHRA & N.A.S.C.A.R Junior Eliminator and NAT. Champion"
The contract you are reading has another page to it, that I'm not going to publish, but it is basicly a winter tour contract.
Eric
2002 Corvette Z06
  #367
Old 11-13-2011, 12:02 PM
Greg,
Eric
Yep, I see the passenger side flipped back around correctly on the engine compartment shot. Missed that before.... and the pre-'67 valve cover mystery goes on...
Old 11-15-2011, 08:24 AM
Keith,
See you soon
Eric
I was at Milford from '86 to '89, so the area code must have changed some time after that...
K
'63 Grand Prix
  #369
I was going to ask Mac that the next time I saw him. He unfortunately passed away before I had a chance -
'63 Grand Prix
  #370
Old 11-15-2011, 08:41 AM
Well, if anyone knew I guess it would have been him.
Old 11-18-2011, 12:24 AM
LUST01's Avatar
LUST01 LUST01 is offline
Mesa changed it's area code in the mid 90's from 602 to 480.
Matt Luster
  #372
Old 11-18-2011, 08:51 AM
Sounds right.
I was at the DPG from 1990 to 1994 (Jan 2, 1994 was my first day relocated back here in Michigan).
K
'63 Grand Prix
  #373
Old 11-18-2011, 03:17 PM
Talking Royal Pontiac Bobcats
Artist David Snyder did a new print of Royal Pontiac called "Bobcats". "Old Cars Weekly" used it on the cover of this weeks issue, November 24, 2011.
David featured my '68 GTO Royal Bobcat convertible up front on the street. Jim Wangers' Judge and '69 Bobcat are in the isle parallel to the street with hoods up. The magazine cover cuts out the old magazine cover shot of Arnie Beswick '68 GTO getting the 428 put into it by Dave Warren and Milt which are seen in the real poster.
The poster can be had at Dave Snyder Carart web site. I all ready bought two and ordered four extra "Old Car Weekly's".
I
2002 Corvette Z06
  #374
Old 11-19-2011, 01:58 PM
"Old Cars Magazine" cover Nov. 24, 2011. Here is the art work from Dave Snyder. "Bobcats" just completed and "Royal Pontiac" a view from 1969.
"Bobcats" shows my '68 GTO convert Royal Bobcat on the street, in front of the used car lot. Jim Wanger's Judge and Bobcat are in the isle behind the front row used cars. In the background you have a recreation of an old magazine, and resent redue, of Dave Warren with the assistance of Milt lowering a 428 into the engine bay of Arnie Beswick's friends '68 GTO. The front end of Jim Wangers' red '65 GTO's with hood up and engine bay exposed in front row of used car is shown close left. Dave took some artistic lisence and chaged the look of Ace Wilson's Royal Pontiac's building. Unlike his "Royal Pontiac" poster which is more accurate.
"Old Cars Weekly" cut the picture along the left side. Eliminating Jim Wangers' '65 GTO and the rear service bay with the engine going into the GTO.
The "Royal Pontiac" poster has many interesting items. The '69 Firebird "Royal" race car in show room. Ace Wilson Jr. is standing next to his personel black '69 GTO convertible black Ram Air III at the side showroom entrance. Jim Wangers is standing in the middle of the used car lot. Jim Wangers' Judge and Bobcat are in the far driveway getting ready to go hunting.
Name:	Bobcats by Dave Snyder.jpg
ID:	263980   Click image for larger version
Name:	Old Cars Weekly Nov 24, 2011.jpg
ID:	263981   Click image for larger version
Name:	Royal Pontac 1969.jpg
2002 Corvette Z06
  #375
Old 11-19-2011, 02:12 PM
Default 1970's Pontiac Engineering Aluminum 507 Block
Pontiac engineers, Tom Nell, Tom Goad and Herb Adams worked on an aluminum 507 cid engine for racing in the early '70's for their pet Trans Am and road racing series.
Several of these blocks are floating around the country. Along with Ram Air V aluminum heads and a Ram Air V aluminum intake with fuel injection system.
You'll find some of my notes along the edge. Several years ago I asked a friend of mine who built dies for Moldex and worked with Sevakis Industries to see if they still have the old Pontiac engine dies or if any one remembers the project. No one at either company worked there back than. After a while these companies usually just call a scrap company to pick up the old dies that will sit outside on pallets until disposed of for pennies on the pound.
Name:	Car Craft Aug 1971 pg1.jpg
ID:	263983   Click image for larger version
Name:	Car Craft Aug 1971 pg2.jpg
ID:	263984   Click image for larger version
Name:	Car Craft Aug 1971 pg3.jpg
2002 Corvette Z06
  #376
Old 11-19-2011, 05:04 PM
Default 1969 GTO red Royal Bobcat
Here is Royal Pontiac's 1968 "Red" Royal Bobcat no longer with a 428 as in "Car and Driver" but now sporting a Ram Air II engine for two "Cars Magazine" tests.
In the June 1968 issue look closely at the photo shot with the GTO at the line. There are two men standing there. The one on the right with a white hat and sun glasses is Jim Wangers. He got caught at a test. Shhh don't tell any one. Some other Pontiac Dealership may get upset.LOL
The second article is from "Cars" magazine November '68 issue with "Motion" doing their "Top Cat" set up on the "red' GTO Bobcat Ram Air II.
That's Dave Warren at the drag strips starters post. Dave would continue to tune the car until it ran at it's full potential!
I'm hoping your beginning to understand who was really responsible for building and tuned these Bobcats......
The last words have to go on next "reply".
Name:	11-19-2011 03;09;09PM.jpg
ID:	264016   Click image for larger version
Name:	11-19-2011 03;10;58PM.jpg
ID:	264018   Click image for larger version
Name:	11-19-2011 03;12;33PM.jpg
ID:	264020   Click image for larger version
Name:	11-19-2011 03;14;10PM.jpg
ID:	264021   Click image for larger version
Name:	11-19-2011 03;17;36PM.jpg
2002 Corvette Z06
The Following User Says Thank You to Dr. Eric M. Schiffer For This Useful Post:
  #377
Old 11-19-2011, 05:10 PM
Default Continued 1968 Ram Air II Royal Bobcat
Continued.
Could this be "Big Red" in a 1969 Grand Prix Ad?
Name:	11-19-2011 03;18;55PM.jpg
ID:	264025   Click image for larger version
Name:	11-19-2011 04;08;54PM.jpg
2002 Corvette Z06
  #378
Old 11-19-2011, 05:20 PM
Default 1968 GTO Red Royal Bobcat RA II
1968 GTO Royal Bobcat in the hands of Motion becoming a "TOP CAT"
By the way have you noticed that Royal Pontiac did "NOT" put any decals on the valve covers? You know, like those "BOGUS" ones sold by some "Judge's" something or other, elsewhere on e-bay and Hemmings.
Name:	11-19-2011 03;36;59PM.jpg
ID:	264029   Click image for larger version
Name:	11-19-2011 03;38;22PM.jpg
ID:	264030   Click image for larger version
Name:	11-19-2011 03;39;53PM.jpg
ID:	264031   Click image for larger version
Name:	11-19-2011 03;41;20PM.jpg
ID:	264032   Click image for larger version
Name:	11-19-2011 03;47;33PM.jpg
2002 Corvette Z06
  #379
Old 11-19-2011, 05:21 PM
Last page of "TOP CAT".
Name:	11-19-2011 03;48;41PM.jpg
2002 Corvette Z06
  #380
Old 11-19-2011, 06:09 PM
Default Royal Bobcat GTO Ram Air I test
How about 2 or is it 3 1968 GTO Royal Bobcats and a 1968 Firebird with Ram Air I's engines? Hummm...
Name:	11-19-2011 04;51;26PM.jpg
ID:	264042   Click image for larger version
Name:	11-19-2011 04;42;51PM.jpg
ID:	264043   Click image for larger version
Name:	11-19-2011 04;44;08PM.jpg
ID:	264045   Click image for larger version
Name:	11-19-2011 04;45;30PM.jpg
ID:	264046   Click image for larger version
Name:	11-19-2011 04;46;48PM.jpg
2002 Corvette Z06
