Old 12-22-2011, 12:11 PM
voyager77 voyager77 is offline
Default SSBC or Baer Upgrades
Hi all, Looking to do my brakes on my 79 T/A WS6. Anybody have any experience replacing the stock rotors/calipers/pads with aftermarket upgrades. Not sure if its worth the extra $ or stick with stock rebuilds. Thanks!
Old 12-27-2011, 01:18 PM
bigborehunter bigborehunter is offline
The SSBC set up was well crafted. My version was polished aluminum and the calipers were excellently made with four pins holding it together for minimum caliper flexing under heavy loads. Real stainless steel lines.The pads were good street units a little higher friction than stock but not track stuff as this was a street car. If I recall correctly, you could use Lincoln Versailles rear caliper units if you wanted a jobber style system. The rear axle to equalizer cables are going to be the only fly in the ointment. The lengths are usually off just a bit. Make sure you use the whole set up in the conversion esp the proportioning valve and adjuster knob if so equipped. A complete factory kit includes proper master cylinder and booster so no special adjustable valve is needed there. I have no exp with Baer but their reputation seems good. Another company is MasterBrake.
Old 12-27-2011, 10:39 PM
Many Thanks!
Old 12-28-2011, 08:06 AM
Don 79 TA Don 79 TA is offline
i put the SSBC dual pistons on in the front
nice looking kit
but i think there are kits out there that allow you to adapt C6 vette brakes very easily
the SSBC kit is nice for a quick easy fit
to bad no one makes aluminum hat rotors to fit in place of stock
that would take so much weight off the front
draw back to other kits is most will require a larger wheel or different offset, so keep that in mind
