I am looking for following NOS or very good condition parts for my 1974 GTO.
Front emblem part # 493693 (Between the grille) Front bumper guards part # 495003-04 Front bumper strips Rear bumper strips part #339474 Rear bumper guard part # 341078 Front inner fender wells (Do you know if these are the same as the Nova) Front #491366 and rear bumper filler Rear fender well mouldings #8707827-28 Rocker moulding #231584 Im sure there are many other parts I will eventually need but thats all I can remember right now. Thanks for your help |
the Front inner fender wells are the same as the nova.
ive had decent luck on ebay
I may have the front bumper guards and strip you seek. I have a 74 Ventura that I installed a 73 front bumper on and do not intend to reuse the original bumper. I assume the part numbers are the same but I will have to check. I would like to have a 73 rear bumper as well and then I would have the rear guards and strip available. By the way, my rear strip was damaged on one corner and I repaired it using rubber bumper repair epoxy available at auto parts stores. Then I painted the strip and guards with bumper black also available. They turned out like brand new and the black does not rub off any more like the original stuff did due to sun exposure. That may be an alternative for you.
Vick
70 Goat 74 Ventura 63 Cat 56 GMC et al. |
I have full set of Gage's for a 74 got with harnesses if your interested. I wasn't sure if you were trying to make a GTO or fix a real one.
1978 Black & Gold T/A [complete 70 Ram Air III (carb to pan) PQ and 12 bolt], fully loaded, deluxe, WS6, T-Top car - 1972 Formula 455HO Ram Air numbers matching Julep Green - 1971 T/A 455, 320 CFM Eheads, RP cam, Doug's headers, Fuel injection, TKX 5 Spd. 12 Bolt 3.73, 4 wheel disc. All A/C cars |
Thanks for the offer mine are all in working order. I know a couple of other guys with 74 GTO's I can ask them if they interested. How much would you be asking for them?
Randy |
Since they are a complete set including speedo/tach and console Gage's with wiring harnesses, $500.00
