67 GTO Type A....
My 69 GTO has the "B" lighter. I had scrounged up an "A" lighter somewhere and figured it would fit because the knob looked the same but I was wrong. You can screw the knob off but the element won't fit in the hole.
I've got the type A in my 62 GP. I guess that's the Rochester. It looks fine, but doesn't work for some reason. All new wiring to boot.
Amazing this got sticky in the Lobby.. must be a 69 GTO is involved LOL
" Long may we DRIVE !" |
'71 and '69 LeMans, both Fremont plant, both Rochester.
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same. -RONALD REAGAN 462 cid/ 6x-4/ TH400/ 3.36:1/ 28x10.5/ 3880#/ 12.35 @ 109.36/ 1.69 60 ft/ 4 wheel disc brakes/ 15 mpg |
Hi Mike, I have a 68 bird with a rochester.
Doug
'72 LeMans, type A.
My 61 Catalina built in California is a type A
67 GTO, built in Kansas City, Type A. Irgoatmike
'67 GTO, K.C., MO - Rochester
'67 GP, K.C., KS - Rochester |
Found this CASCO tag this weekend while sorting thru some stuff in the basement. I wonder if they are reproduced. Be nice to attach to the lighter while at car shows.
http://ultimategto.com/cgi-bin/picse...=&comm=&page=1 |
I have a limited supply of Casco lighters and I'm planning to make some 64-5, 66, and 67-72 lighters this week.
Thanks for all your help. GP MIKE |
Have you tried checking to see if there is current to it.. the outer shell is negative as its ground to the dash frame, and the centre is positive.. should have power all the time. Funny the lighter nowadays is to charge up an ipod or something like that and not a smoke :>)
I have a 1969 GTO built February 69 in Fremont CA with a type B Casco lighter. The knob is smaller, though, and it has the light which clips onto the outer case. Do you sell the Casco lighter by itself with the larger knob?
Thank you for responding to my post. I have decided to make 3 different Casco lighter packages...
PYI72LCK - http://www.pysales.com/images/pyi72lck.jpg for $40, PYI73LCK - http://www.pysales.com/images/pyi73lck.jpg for $40, PYI74LCK - http://www.pysales.com/images/pyi74lck.jpg for $40. There is a limited supply instock, so for anyone who needs them, please give us a call for order online. Thanks... GP Mike |
I've never seen a casco style in an F body. Although I changed mine over to casco. I put the original knob from my Rochester onto the casco element with casco socket. Pretty much looks original but I don't have to worry about a melt down anymore.
1978 Black & Gold T/A [complete 70 Ram Air III (carb to pan) PQ and 12 bolt], fully loaded, deluxe, WS6, T-Top car - 1972 Formula 455HO Ram Air numbers matching Julep Green - 1971 T/A 455, 320 CFM Eheads, RP cam, Doug's headers, Fuel injection, TKX 5 Spd. 12 Bolt 3.73, 4 wheel disc. All A/C cars |
#38
What is the difference between the PY172 and the PY174? Thanks -
#39
My 65 Lemans has a type B but the knob does not match the other knobs which all look like the Type A.
I recently purchased a new type A to match the knobs but its too large to fit in the socket???????? The type B lighter I have works great but looks like crap sinse it dosent match the knob of typr A.--------Hope I didn't confuse you. |
#40
Type A 69 FB
