Old 01-26-2012, 09:47 AM
My72455 My72455 is offline
Default Too much play in shifter
I put my original shifter back in my '72 and now I have too much play when I upshift from 1-2-drive. The shifter doesn't even line up with the "D" when I am in drive and theres a lot of play and movement. Took the shifter all apart to check if I missed something and tried to tighten up shifter cable underneath but it didn't fix anything. Help now what? I have a turbo hydromatic 400 transmission.
Old 01-26-2012, 12:28 PM
Forrest's Avatar
Forrest Forrest is offline
Make sure those little "C"clips at the ends of the cable (trans. bracket and at shifter) are fully in place and in the correct place!.. and that the shifter cable is fully and correctly attached at both ends...this has caused me problems before.. like the loose shifting problem
Old 01-26-2012, 10:03 PM
thank you. I will look at those things and reply back if it works! We are going to replace the shifter cable because it's the original one and PY tech support said this could be a cause
Old 01-30-2012, 09:19 AM
2002Z4CSS's Avatar
Sounds like the shift cable is stretched or mis adjusted.
1971 Pontiac GT-37
Old 01-30-2012, 10:50 PM
pont3 pont3 is offline
You also have some adjustment in the shift rod (the vertical rod that activates the steering column lock collar), and a half inch or so adjustment where the cable attaches to the tranny. Are you sure the cable is the original one? Or an incorrect replacement that was installed prior to your owning the car?
Old 07-26-2013, 10:01 PM
pmdclassics's Avatar
pmdclassics pmdclassics is offline
Any more on this topic. I too have the very same issue with auto shifter slop or way too much play in the shifter. It moves loose about a half an inch both ways.
TODD
Old 07-26-2013, 11:05 PM
Rhamm71 Rhamm71 is offline
Has anyone found replacement parts or components for these shifters
Old 07-26-2013, 11:07 PM
I pulled it all apart tightened it and changed the spring that controls the push button and its way better, idk if you all tried that or not
Old 07-28-2013, 04:49 PM
CraigGT37's Avatar
CraigGT37 CraigGT37 is offline
I worked at a place that had a machine shop, I had one of the machinists make a set of the plastic guides for me. He used delrin for the replacements. My guides were worn allowing the sloppiness.
Craig
Old 07-30-2013, 02:41 PM
gtohurstjudge's Avatar
gtohurstjudge gtohurstjudge is offline
Usually all you have to do is tighten the side bolts as they vibrate
loose with time.....normally the guides don't wear out in my experience.
