Old 02-03-2012, 04:35 PM
Goat-Racer's Avatar
Goat-Racer Goat-Racer is offline
Default loaner dyno headers
I just completed a freshen up and cam change on the 496. We will be at the Vrbancic bros. dyno (The Carb Shop) in Ontario this coming Wednesday the 8th.
The plan is to spend most of the time on the Doug's 1-7/8" headers that I run in the car, but I would like to try a 2" or larger primary on the engine to see what I may be loosing vs. the little street headers. George was not too sure if he had Pontiac round port headers at the shop, so I wanted to throw out some feelers and see if anyone locally had a set that was available to try?
Shoot me a response, a PM, or give me a call @ 805-714-0490.
Thanks!
Brian Rock
'65 GTO - Pump gas 496" IA2 w/ High Ports, 200-4R trans, 3.73 gears, 275 Hoosier radials, and 3925 lbs.
9.88 @ 134 N/A on Cali 91 octane.
http://www.youtube.com/watch?v=NJEIY5OJ68g
Old 02-03-2012, 04:58 PM
cgeise's Avatar
cgeise cgeise is offline
I sold a set to a guy in Sonoma last year ???
Old 02-03-2012, 06:40 PM
SergeF SergeF is offline
Last time I was at Harry K dyno shop I saw a few header sets overthere.
Old 02-03-2012, 06:56 PM
Ron's Avatar
Ron Ron is offline
Good luck with that Brian. If I can find the time I will try and stop by and say hello.
Due to the current economic conditions...the light at the end of the tunnel has been turned off.
Meet you at the finish line.....don't be late!
Old 02-03-2012, 07:44 PM
Goat-Racer's Avatar
Thanls, I'll shoot him a message.
Brian Rock
Old 02-03-2012, 07:46 PM
Goat-Racer's Avatar
That would be great Ron, It's been awhile! We should be there all day.
Brian Rock
Old 02-03-2012, 09:26 PM
mike leech's Avatar
mike leech mike leech is offline
not sure how much you're making. 1 7/8 should be good for up to 700 or so hp. please post the results.
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
Old 02-03-2012, 09:46 PM
R 70 Judge's Avatar
I have a set of Hooker 68-72 GTO headers laying around. 2" primary with a 3 1/2 collector. They are dented up a bit, but should still work. Trouble is I'm all the way down in San Diego. Is anyone from my area heading up for your dyno runs that could grab them?
James
1970 Trans Am
Old 02-04-2012, 02:36 AM
racegto65's Avatar
racegto65 racegto65 is offline
Yea, but I live in Las Vegas!!!!
Old 02-04-2012, 11:50 AM
Goat-Racer's Avatar
Well, the cowboy math by weight, ET, and MPH indicates that I'm already at that level or just above. The cam change, while not a huge difference, should pick up another 20 or 30 if the plan comes together
The old cam is a Harold Brookshire solid roller(263/[email protected] 108lsa .650" net) that was ground for the old 421. I'be been using it for the past two years in the 496 and now that freshen up time is here and the car seems to be stuck in the 10.0x range, a proper cam for the bigger engine was most cost effective change to make. The new cam is also from Harold, and is 268/278 108lsa, .710" net, and a touch fatter at. 200" than the last one.
So, I don't really care what the HP value is, as long as long as the ET goes to single digits I'lll be happy.
Brian Rock
Old 02-04-2012, 01:06 PM
Old Man Taylor's Avatar
Brian - My engine was on the dyno at Vrbancic Bros in 2007. At that time they had a set of 2" round port headers for a Pontiac. They had the sensor fittings in each individual tube.
Old 02-04-2012, 01:17 PM
Goat-Racer's Avatar
Thanks Jim. George couldn't remember for sure. That will make things much easier.
Brian Rock
Old 02-04-2012, 01:42 PM
Skip Fix Skip Fix is online now
Have some 2" Hookers with EGT fittings in every tube if you pay shipping.
Old 02-05-2012, 02:42 AM
Here they are.
Name:	2007 Dyno Runs 003 bright crop small.jpg
Old 02-05-2012, 09:23 AM
Goat-Racer's Avatar
Those will work. Close in design to what is on the car now, and not so much a set of dyno only "magic" headers that would never fit in the car.
Thanks to all that offered, and if anyone is in the area, please feel free to come by and visit. It should be a good day.
Brian Rock
Old 02-06-2012, 01:33 PM
cgeise's Avatar
ooops - -forgot -- age is hell -
Old 02-08-2012, 10:05 AM
Goat-Racer's Avatar
We made it down to Ontario yesterday afternoon and had time to get the engine mounted on a dyno cart. Hoping for an early start and a good day.
Brian Rock
Old 02-08-2012, 10:13 AM
mike leech's Avatar
please post up your results...and good luck
EHTTFMF!
Old 02-09-2012, 02:23 AM
Goat-Racer's Avatar
OK, here is the quick rundown after a long day at the dyno. 35 pulls, 771 HP @ 6700 and 702 foot pounds @ 4700 on California 91 octane cat whiz.
The good cheater oxygenated VP 109 Ms gas netted 785/704.
Time to retire after a good bacon cheese burger and a half a dozen adult beverages!
Brian Rock
Old 02-09-2012, 02:26 AM
R 70 Judge's Avatar
Congrats! Excellent numbers! You should make another thread with all of the details.
ps. Our gas here is freaking horrible
James
1970 Trans Am
