Old 02-09-2012, 05:10 PM
dataway's Avatar
dataway dataway is offline
Default Dash Pad preservation
The original dashpad for my 68 GTO is in storage right now (if you call sitting on a shelf "in storage"). It's got one crack in a fairly out of way spot, about 3" long. I'm trying to keep it that way.
Any tips for storage, and "stuff" like Armor All to help preserve it. It's quite delicate and you might imagine. Stiff, but not rock hard, there are places with flex left ...but a punch and it would crack I'm sure. Should I bag it? It will be stored another 18 months or so.
JohnnyB
Old 02-09-2012, 05:30 PM
mrrat1 mrrat1 is offline
I would blanket & plastic wrap & box it up. Can't comment on what to apply to it. I have mine in the attic so nothing can accidently happen......
Old 02-09-2012, 05:39 PM
Stuart's Avatar
Stuart Stuart is offline
I'd put it under the bed in the spare bedroom, or someplace similar - you want it laying flat so it won't warp, and in a location where it won't get bumped and stuff won't get piled on it. Also, it should be a location that doesn't get too hot or cold.
Old 02-09-2012, 06:59 PM
GT182's Avatar
GT182 GT182 is offline
Armor All sure won't hurt it, and it's better than nothing.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 02-09-2012, 08:20 PM
65Mark 65Mark is offline
I wouldn't use Armor All on anything. One, it's full of silicone, two it's been known in the past to dry stuff out. Maybe it has changed since the 80's.
Old 02-09-2012, 08:22 PM
Cammer-6 Cammer-6 is offline
baby oil will help soften it
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 02-09-2012, 08:29 PM
Yeah but it takes several babies to get enough oil.
Old 02-09-2012, 10:07 PM
carcrazy carcrazy is offline
I would try to keep it in conditioned space if possible where temperature variance is at a minimum. I stored my "perfect" 67 dash in the attic for about 5 years. Wasn't perfect anymore when I removed it-very brittle and had to get another.
Old 02-10-2012, 09:55 AM
69Customs's Avatar
69Customs 69Customs is offline
I've seen Armour all turn black dashes white over time from use. I used baby oil.
Old 02-10-2012, 10:41 AM
70 Rick's Avatar
70 Rick 70 Rick is offline
One word= Vaseline
Old 02-10-2012, 04:44 PM
dataway's Avatar
I will certainly try some vaseline .... the orginal vinyl used back in the day is/was a petroleum product correct? Does seem like baby oil or vaseline might work in that case.
JohnnyB
