| THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
| View Poll Results: Best Big 3 Truck. | |||
| Chevy |
103 | 47.03% |
| Dodge |
43 | 19.63% |
| Ford |
73 | 33.33% |
| Voters: 219. You may not vote on this poll | |||
#41
Are we talking about "trucks" here, or cars with beds on them?
Unless your truck has 8 lug nuts per wheel, full floating axle, and rated over 10,000lbs towing, it's a light duty truck, or closer to a car with a bed on it. In the light duty truck range, they all have their shortcomings. I've owned two Chevy trucks, and two Dodge trucks since 1998. I bought a 6.5 turbo 1998 truck with a 4L80E trans in 1998, brand new. It was OK, aside from eating lift pumps, and underpowered (no intercooler), never grumbled once in the 100,000 miles I put on it. I sold it and bought a prestine 1992 Dodge with the 5.9 Cummins turbo diesel, with only 20,000 miles on it. I ran that truck till it would go no further. It was just OK, as the early diesel set-ups were low on power and the 518 transmission is a piss-poor way to put diesel power on the ground. Even with a billet converter and my best efforts inside the transmission, the gear spread is all wrong for serious towing in that platform. With 3.54 rear gears, it's too many rpm's in 3rd, and not enough in 4th at highway towing speeds. I replaced that truck with a 2001 Dodge 24 valve 5.9 Cummin's with the NV4500 transmission and 4.10 gears. MUCH better at every level. Ran that truck till it was in need of replacement, and went with a 2007 Silverado with the Duramax/Allison set-up. I never even looked at Ford trucks at all, but LOVE the looks and heavy duty chassis. They are NOT very popular in these parts, guys that are serious about towing absolutely HATE the 6.0 diesel set-ups. The 7.3 intercooled Ford trucks were, and still are, very popular, if you can get a transmission beefed up enough to hold the power, which is an expensive undertaking (E4OD). Anyhow, overall I'm pretty content with the Duramax/Allison. I've added 4" exhaust and a Predator programmer (doesn't really need it). It rides like a Danali and has the power of the 24 valve Cummin's, just doesn't make all that noise. The Dodge edges out the Chevy for fuel economy, but not on power. The Duramax is a strong runner, easily managing the steepest grades with 10,000-12,000 pounds behind it, and you can still here the stereo just fine at any speed or engine rpms. The Dodge pulled just as hard, but you had to SCREAM over the turbo (over 40lbs boost) on hard pulls. I still have a soft spot for the "rough and grumbly" Dodge with the manual transmission. The Duramax seems like a "sissy" truck in comparison, but does everything equally as well, if not better, while riding in a quiet comfortable cab. My Dodge would get near 25mpg's on trips unloaded, never once under 20mpg's on the highway empty, and 11-15 towing. The Duramax will see just over 20mpg's empty, and 11-13 towing. Don't know how the Chevy will do in the long haul? It's only got 40,000 miles on it right now, and no problems anyplace to date. I'm due for a new shop truck this year, so may not find out. As for a vote, I'd take the Ford Super Duty chassis, Cummin's engine, backed by the Allison 6 speed transmission, if I had that choice.....Cliff
#42
I agree with you Cliff - this discussion is all over the place. Limit it to 1-ton or to lighter duty trucks - I like both my 2000 F-350 7.3 & my 2007 Tacoma, but they don't belong in the same conversation as they have vastly different uses.
Some guys they just give up living And start dying little by little, piece by piece, Some guys come home from work and wash up, And go racin' in the street. Bruce Springsteen - Racing In The Street - 1978 |
#44
I would also add that these 5 and 6 lug nut trucks have no place towing car trailers up near 10,000 lbs or greater.
I actually got pulled over in NC coming back from Florida pulling my 24" trailer with six full size Harley Davidson motorcylces in it. The State Trooper saw my Chevy truck pulling the trailer and whipped across the median and pulled us over. When he got up to the truck, he realized it was the Duramax/Allison and commented that he thought it was a light duty 1/2 ton gas truck pulling too much weight. We had a brief conversation about it, and he went on his way. They are cracking down HARD on guys pulling heavy loads on the Interstate with light duty half ton trucks, so be aware of it. They will do the same thing to you here in Ohio. Several folks I know have been pulled over and ticketed for pulling too much trailer with not enough truck....FWIW.....Cliff
#45
Imported repopped aftermarket parts are defended more than US companies. If I were in the market for a new light duty truck, I would look at a GM or Ford. It would be based on personal experience and research. I just bought a new (used) car, and looked at both brands. I chose GM again. I could name several things I liked about the Fords and things I didn't like about some GM products. There is a lot of good data stated and posted and a lot of very knowlegeble people. But when posts get full of hate, I just skip to something I can learn something from. Last edited by iowapub; 02-15-2012 at 09:22 AM. Reason: Thanks Cliff! I am due for a new truck and posts like yours really help. |
#46
I almost bought a Ford but due to their Inter-Cooler and/or Electronic Steering I bought a GM. It all depends on how your going to use the truck and for me its plowing, hauling, trying to get stuck...what a truck is for.
Oh, I also decided to keep my money here in the states and bought a USA product instead of one that is just assembled here. |
#47
1966 GTO 1969 Lemans Convertible- F.A.S.T. legal family cruiser. 12.59 on G70-14 Polyglas tires. 1.78 60' 1969 Bonneville Safari- cross country family cruiser. . 1979 Trans Am 400, 4-speed, 4 wheel disc. View from the drivers seat racing down Atco Raceway- http://www.youtube.com/watch?v=GhYDMdOEC7A Ride along in the other lane-http://www.youtube.com/watch?v=mIzgpLtF_uw |
#48
What I did was not stalking. I responded to what you posted on this thread. You can't respond on topic to my post, so you take something from another thread and try and change the topic. Why? Because you can't prove a point. And yes, what you did on the thread you're referring to was stalking. When you take a personal photo of a board member - posted on a thread requesting folks post photos of themselves - and then create a "Brokeback Mountain" title for that same photo and post it on a totally different thread and make derogatory comments - that's stalking. I guess if that's what you need to do to make yourself feel superior - have at it. I can deal with you calling me "chump", "gay", "hick", "toothless" and with your making comments about my wife's appearance. To me, and many others here, you keep getting smaller with each post. |
#49
I bought a 2000 Chevy Silverado LT (5.3 ) , brand new. It has treated me well. Except: 1) I replace the window "winder" on each door every other year. and 2)There is a little Diesel sound in the cooler weather. It lasts about 15-20 seconds. I have been told that it is a wrist pin clearance issue, is 'normal'., and not to worry about it.....105,000 miles now. If I were to buy a new pick-up todat, I would probably go FORD F-250...based on looks alone . I haven't researched powertrain, etc. Eric
#50
I have to admit i just bought a cough cough Dodge Ram 1500 from a buddy that needed money. Its a 2004 reg cab short bed with the 4.7 and has 251,000 miles. The ONLY thing that has been done is routine service, brakes/rotors, and a new radiator. Have to admit I kinda like it. So now i have a Chevy 2500hd, Ford F-150 Company truck, and a Dodge . LOL
#52
#53
Without reading all the replies.... Ford, cause they didn't take the money
#54
You ever heard of "We the People ?" It felt like "We the Government Motors" when the facts came out - Quote:
![]() Never called you gay, or made remarks about your wifes looks. You brought that up, so quit bein such a teenage drama queen. You're a Chebby guy. Chebby wins everything, Chebby did this, Chebby did that. You remind me of why I started disliking Chebby guys years ago; I can't count how many Chebby followers told me to put a 400 Chebby under the hood of my 65 GTO when I had it ![]() I only choose Ford beacuse my trucks get worked and until International brings back a pickup , that's what I'm sticking to. None of the Chebbys we've used could hold up to the hell we put 'em through. And if we're talking tough trucks for longevity, working like a truck, and taking a beating like a real truck an old International would whip 'em all
Two 1975 455 Grandvilles & '79 455 Trans Am ‘69 Camaro SS 396/375 (owned since ‘88) ‘67 Corvette 427/435 ‘23 Lexus LS500 awd ‘20 Audi R8 & ‘25 Toyota RAV4 (wife’s cars) ‘95 Ford F250 4wd 7.3 p-stroke & countless Jeeps & off road vehicles & motorcycles |
#55
Chevy Dodge & Ford comparisons testing: 1977 "Battle Of The Big Blocks" (Car Craft)
1977 "Battle Of The Big Blocks" (Car Craft) Page 1 Page 2 Page 3 Page 4 King Rat: 454 'Big 10' Pickups scorched the 70's! http://www.gminsidenews.com/forums/f...12/index3.html Quote:
Chevy Duramax or Tundra
#57
Fact is, you were so embarrassed to see the ecobust lose to the Chevy in BigUnde's post. You just had to post another youtube showing the ecobust winning. Funny thing is, there was another youtube showing the ecobust losing in the other lane. Quote:
I've posted multiple times about GM's dominance in NASCAR and dirt track racing. GM has won Championships with multiple car divisions. GM beat Ford to their first manufacturer's championship with Oldsmobile in 1955. Chevy then won in '58, '59, 60 and '61. Pontiac ended that streak by winning in '62. Ford has a nice little run in the mid 60's when GM had the racing ban and then Chrylser boycotted NASCAR (pretty easy to win when you run by yourself). In the 70's, GM won 7 of 10 with Dodge getting 2 and Plymouth 1. In the 80's, GM won all 10, including 2 by Buick. It wasn't until 1992 that Ford finally won another championship. (helps when Ford only ran one brand and GM had to split their points between Chevy and Pontiac). Regardless, GM still won more in the 90's than Ford. In the 2000's, Ford has actually done worse than the 90's - only winning 2 of 12 championships. If you want the final numbers - that's 39 championships for GM, 15 for Ford, 3 for Mopar and 3 for Hudson. Quote:
![]() http://www.youtube.com/watch?v=4CGYA04DNTY I will give Ford credit though - they are much better than the Toyota. But then, I've never considered Toyota to be much of a truck. (you may want to cheat and just go to about 4 minutes in - Ford people take a long time to talk about the fluff) http://www.youtube.com/watch?v=zRfE_XAk2mE Quote:
#58
Next time you are running down interstate just count the number of one tons you see pulling heavy loads. You will notice that ford and dodge will be pulling the big loads and duramaxes will be pulling the campers!
#59
Well one thing almost everybody agrees on is that IH builds better trucks than any of the big 3.......... Finally something almost everyone agrees on.......................
![]() ![]() IH headquarters has been in Springfield Oh. If they just built something in the light truck field they probably couldn't build them fast enough.
Brad Yost 1973 T/A (SOLD) 2005 GTO 1984 Grand Prix 100% Pontiacs in my driveway!!! What's in your driveway? If you don't take some of the RACETRACK home with you, Ya got cheated ![]() ![]() ![]()
#60
