Old 11-21-2011, 12:17 PM
Sloan66's Avatar
Sloan66 Sloan66 is offline
Default 66 GTO w/ Poverty Caps
15x7 GM steel wheels with BFG from Diamond Back 235/60/15 all around, hotchkis springs
  #82
Old 11-23-2011, 10:42 PM
ramair3 ramair3 is offline
Default 69 Judge
Wheels and tires
Centerline Lazer II polished 17 x 8 fronts w/ 4” backspacing
Centerline Lazer II polished 17 x 10 rears w/ 5” backspacing
Goodyear Eagle F1 tires, 245-45-17 and 285-40-17
Picture with tire under rear of car is a BFGoodrich radial T/A is a 295-50-15, but shows what a 285 would look like.
ID:	264633   Click image for larger version
ID:	264634   Click image for larger version
ID:	264635   Click image for larger version
  #83
Old 02-02-2012, 07:21 PM
VAB5 VAB5 is offline
Pontiac Rally II HW Code, 15 x 7 at all 4 corners
1/4" offset, 4-1/4" backspace
BFG T/A RWL, 235/60R15 front and rear
  #84
Old 02-27-2012, 12:01 PM
Nikwho's Avatar
Nikwho Nikwho is offline
Here is my '67 Tempest. It has 275/60-15 Cooper Cobra's on 15x8 wheels with 5.5" backspacing on the rear. 215/65-15 Cooper Cobra's on 15x7 wheels with 4.5" b.s. on the front. No engine/tranny in the car, it will sit pretty low. It is on Hotchkis front springs and Jeep TJ rear springs.
'67 Tempest Custom - Resto Mod 462/TH400
'59 Chevy Apache 350/700-R4
  #85
Old 03-18-2012, 07:31 PM
firebirdmi firebirdmi is offline
Front: 235/45/R17 Nitto 555 on a 9" wide/5" backspace Year One Rally 2 (will switch to 8" wide when they come in)
Rear: 255/45/R17 Nitto 555 on a 9" wide/5" backspace Year One Rally 2
  #86
Old 03-18-2012, 08:08 PM
torqjunki's Avatar
torqjunki torqjunki is offline
Man that early bird looks good! Are those the polished wheels or is the center light silver? Can you get those in 15's 9" wide?
1971 Base Firebird..505ci IA 2A Round port E-heads by Butler 348 cfm.. Comp street SR 266/[email protected] Victor intake/Quick Fuel Q950. 1 7/8" Dougs headers..3" mandrel bent exhaust with Hooker Max Flow mufflers, T-350 well built with 10" 4000 stall nitrous Continental converter..3.73 posi . Caltracs and 10" slicks. Belt driven water pump, alternator, Pwr steering and brakes,Flex fan. 11:1compression, straight 93 octane pump fuel. 10.35 @ 129.88 with 1.45 60ft N/A at 3700lbs race weight.
  #87
Old 03-18-2012, 09:58 PM
Front Cragar 15x7 4" BS with 215/70/15
Rear Cragar 15x 8 4 1/4" BS with 255/60/15
  #88
Old 04-07-2012, 11:06 AM
riskey69's Avatar
riskey69 riskey69 is offline
Default 1970 GTO
Here are pics of my 70 GTO. 15 x 8"(4.5" backspace) rim in back 15 x 7"(4" backspace) rim in front. The car is a 455 car so, it has the 12 bolt rearend in it withoriginal suspension. I am not sure if anyting was changeed on the front end. Tires size 255/70/15 (rear) 245/60/15 (front)
ID:	280890   Click image for larger version
  #89
Old 04-21-2012, 12:01 PM
cnc's Avatar
cnc cnc is offline
15x7 235/60/15 4.0 B/S frt
15x8 255/60/15 4.5 B/S Rear
Rims are US MAGS
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
  #90
Old 04-21-2012, 02:13 PM
16x8 Vintage 45's.... 4.5" backspace....... 245/50R16 front.... and 255/50R16 rear... I move my tire and wheel packages around....
  #91
Old 04-21-2012, 02:17 PM
16x8 American Racing Torque Thrust D's.... 4" backspace........ 245/50R16 all around.....
  #92
Old 04-21-2012, 02:28 PM
15x7 Wheel Vintique Rally II's.... 4" backspace..... 235'60R15 BFG's.... they just about tore the fender off my '70.... they fit better on the '71 GP
  #93
Old 04-21-2012, 03:27 PM
cnc's Avatar
cnc cnc is offline
How do u get the pic to fit the WHOLE page
71GP76TA nice toys
  #94
Old 04-23-2012, 01:04 PM
71GP76TA nice toys
I don't know..... I just copy and pasted the pics from my photobucket account.
  #95
Old 05-19-2012, 08:33 PM
1969GTO's Avatar
1969GTO 1969GTO is offline
PontGuy
what are your wheels back spacing?
color me gone
  #96
Old 05-25-2012, 07:47 AM
PontGuy's Avatar
PontGuy PontGuy is offline
PontGuy
I knew the codes and details when I bought the wheels three years ago, but this thread has been running a long while now and to be honest I don't remember. All I can tell you is that they are original early 15x7 Rally II's. But here's an updated pic- same wheels and tires but with new paint and trim on the car.
I also replaced the rear with a 12 bolt 3.07 posi from a 72 GTO and added a sway bar a few months ago. No change to the stance but the new combination is perfect- on the street it hooks better than my 06 GTO. I haven't tried it at the strip... yet. Pic was taken before the rear end swap.
1969 Lemans vert, matador red, 462 CI, 3.07 12-bolt posi
1974 455 TA, admiralty blue/red interior HPP "cover car" - sold
"The best way to show a car is to drive it"
  #97
Old 05-29-2012, 08:32 AM
PontGuy's Avatar
A fellow PY member just posted this link in the 68-69 GTO tech section. It provides specs for all of the stock Pontiac wheel codes. Figured it would be a good reference here.
http://www.pontiacserver.com/wheels.html#rally2
Based on the chart I am sure that my back spacing is 4.75"
  #98
Old 06-04-2012, 12:30 AM
hada76's Avatar
hada76 hada76 is offline
295/50/15 on 8" flakes
Name:	beach car show 002.JPG
  #99
Old 06-04-2012, 09:31 AM
1969GTO's Avatar
looks like Daytona.....hada76
color me gone
  #100
Old 06-04-2012, 11:48 PM
hada76's Avatar
ormond, spring turkey rod run
http://www.youtube.com/watch?v=W_8JM...eature=related
