The one pattern looks ok? But If u look at the other to the right it is quite far down the valve tip, I would go about .100 shorter also..
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,[email protected]@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected] M/T 275/60 ET SS Drag Radial 2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's |
"If you are concerned with the location of the roller rocker sweep path and are convinced that it should be centered, there are steps you can take to improve the situation."
Rocker Arm Geometry And Valvetrain Alignment A Detailed Explanation Of Valvetrain Alignment Goals http://www.circletrack.com/techartic...y/viewall.html .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE |
9.15" it is.
I re-checked my pushrod length using 9.1", 9.15", and 9.2". 9.1" gave me a pattern about center. 9.15" gave me a pattern just to the exhaust side of center. These checks where with a hydraulic lifter pumped up and a week check spring. My thinking is with my lifter pre-load added in, 9.15" should be just about wright. Watching the rocker arm move through its stroke, 9.1" seemed to give a more even movement looking closer to 90deg at 50% lift. Any one have a good set of 9.15" pushrods with at least .080" wall for sale?
1967 Firebird project in the works 400, 670 heads, 2802 cam, Hooker comp, Crosswind intake, Quadrajet, 700r4, 3.42 Posi. |
"Are you saying if your combo needs more lift all we need is longer pushrods?"
No I am not, just saying go measure one with several different lengths and dial indicator or pull op Pete's old article where they did that and it will more than just a few thou either direction. It does impact it just as swapping to different rocker brand can even if the ratio is identical as they use different roller tip diameters, and different geometry for the pushrod cup height vs fulcrum and roller tip. I have measured total lift while checking pushtod lengths and it definitely changes.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
Anybody?? I'm going to be installing a hydraulic roller cam soon, and I am confused as how to measure for correct push rod length. I was told I can't use a solid roller lifter as a "checking" lifter because it is way shorter than a hyd roller lifter, so what is the secret?
Thanks for the response. Some questions:
1. Is a "shelling" rod the push rod measuring tool? 2. Don't you mean subtract the .48" difference, to get the correct push rod length? 3. How tight do you make the rocker arm stud nut -- just to zero lash? 4. Do you have to compensate for the extra 1/2 (approx.) turn past zero lash that you do with hyd lifters? If so, how? |
